Question about ViewSonic NextVision N4060w 40 in. LCD Television
Our tv started by not switching on until it had been switched on and off several times...now there is no power light at all in it. when plugged in the power on and off light flickers then goes out. is it a huge problem or would it be repairable
Replace the c21 and c22 capacitors on the power supply....it's easier than you think...you'll need a low watt soldering iron from radio shack, some desoldering braid and a little patients. the capacitors are around $1 each. the are 1500uf, 16V.
Good luck.
Posted on Mar 02, 2010
The lap top will not switch on
Power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
select Reboot Tablet Normally.
Feb 02, 2015 | ARNOVA Tablets & eReaders
Lights went out breaker was thrower switched breaker to on several times when I came in tv would not come on electricity is good to it so is their a fuse and where is it on tv or is there a nother place on...
Pull the TV plug out of the electrical outlet. In fact, pull all plugs from all nearby receptacles. Try the circuit breaker. If it still trips, pull more plugs from the receptacles untill the circuit breaker no longer trips. Reverse the process to isolate the plug that is causing the circuit breaker to trip. Repair broken item.
Apr 12, 2013 | Televison & Video
It started when i started using the TV card (PCI). when the tv card is inserted the processor fan will start making noise and the same part becomes hot. from time to time it was failing to switch on but i...
With the tv card installed the PC might have problems maintaining the correct voltage, there might be a power overload, too much current is being drawn from this tv card and therefore your pc is working harder to run your system, make sure you have a good power supply or replace the power supply too a more potent one. Also make sure your motherboard is compatible for it. Good luck...
Apr 28, 2010 | Dell Latitude C640 P4 Mobile Notebook
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My tv seems to be dead...
Ur power board ic converter is dead.
Need a new one.
Aug 18, 2009 | LG 42LC2D 42 in. LCD HDTV
AStar Ltv-2701
It appears to be a power supply failure. In about 95% of cases is a defective power supply that causes the TV to behave as per your description.
If you need more info you can email jah2mil@hotmail.com
Jul 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Feb 29, 2008 | Pioneer PDP-5071HD 50 in. Plasma HDTV
The tv wont start
there is an input button. Press this button untill you reach the input that you plugged into.
Jan 05, 2008 | Panasonic TH-50PX75U Plasma HDTV
Open Questions:
Viewsonic n4060w I was changing my chanel from the console, then the screen went blank. I can hear sound. I try to view the menu or sources but nothing. I can turn the tv on and it lights up a little but still cannot see anything. First, I had trouble with turning the TV on/off -- I could turn it on from the unit, but had to turn it off on the remote. Then, the on-screen menus started going haywire in that, as soon as you pressed the menu button, the TV would automatically quickly go through all menus on its own -- so fast, that you couldn't stop it. I had a local TV repairman come and he said that it was either the board for the TV's control buttons, and/or the main board -- which I guess is the inverter board(?). He ordered both from Viewsonic (apparently, anyway), and voila! TV started working again... but only for a week. The new problem was that it wouldn't turn on at all now. So they ordered a replacement for the two boards AND a new power supply. Lo-and-behold, he got a garbled mess to display with the new boards before he put in a new power supply, and deduced that the power supply was not the problem (and returned it). So, he said the new main board that was sent was defective, and ordered another. Today they came and attempted to put in the newly arrived main board, and it was missing capacitors (and, obviously, the TV is not working still). So, they are ordering another. I just sent him a link to an on-line store www.discount-merchant.com who had some parts available, one of which it claims is video board for an N4060W. Holding my breath now, I guess. Viewsonic is a nightmare!
May 27, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
ViewSonic NextVision N4060w 40 in. LCD Television Logo
253 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
