Question about OKI B4600 Printer
After every page I print, the green light goes out, and I have to press online to get it to continue printing.
  • OKI Master
  • 1,113 Answers
Thats ..paper size mismatch, check the paper size settings of your printer in printer properties is the same as what document or document program is set to under page size of the document you wish to print, if these dont match the printer goes offline so you can put in what it's been told is the right size paper or press online to force it to print regardless...so in your case check paper size in both locations and you should be right, there are other things but 99% of the time..thats ya baby;)
Cheers
Posted on Nov 15, 2009
Hi, the green light is steady on the lightbulb icon. And im unable to print
This light sequence means that the printer is ready to receive and process data but it is in Power Saver mode.
If a print job is sent, Press Continue to print the menu settings pages for a list of current printer settings. You may also Press and hold Cancel to reset the printer.
Please call Lexmark Technical Support for additional assistance.
Jul 09, 2011 | Lexmark E260dn Laser Printer
When I want double sided printing with samsung ml2010 printer, the online error stay red after one side is printed. Then i can do nothing but turn off the power button. it goes well when one sided...
I solved it!! Just hold down the Cancel button and I think it acts as the OK button. The red light will go away and turn green and it will print the odd pages. There you go!
Dec 18, 2010 | Samsung ML 2010 Laser Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
Printer wont go online - light continually flashing green to yellow...
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Office Equipment & Supplies
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Tally 2280+. While printing, goes offline and displays paperjam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
HP 2420 sudden prints pages in all black
Most likely to be the toner cartridge is it OK on other programs such as the web explorer? If not change the toner cartridge you can also print out the configuration page by pressing the green tick and then using the up and down arrows select information press green tick to enter then move to "Print Configuration" and select using the green tick. If the page comes out OK then the print cartridge if fine if not try changing it. Also there maybe in the driver you have under printing preferences negative mode make sure that is not checked.
Failing this reinstall the print driver from HP Online if this still doesn't work then change the data cable if still not working then I suggest that the printer formatter board is faulty.
I do hope this helps you and please rate me
Thanks J
Dec 30, 2007 | HP LaserJet 2420 Printer
OKI B4600 Printer Logo
625 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
