Question about Rotary RotoZip XB-LF5 Laminate Flooring X Bit
How to lay laminate flooring - Rotary RotoZip XB-LF5 Laminate Flooring X Bit
    Problem Solver:
  • 13 Answers
Start against your longest wall. clip three rows together and slide lightly against the wall. put shims of wood in the gaps between the wall and new floor to make it solid. continue adding planks from there.
Posted on Jun 11, 2010
    Director Badge:
    Uploaded 100 video answers.
  • 96 Answers
Here you go. See this video or search "comeinhandynow laminate" on Google.
Posted on Oct 29, 2015
NOt t all happy with my 1year old style selections laminate floor. It creaks with every step. Has hooked up
contact the floor layer who did the job and check on the work and material warranty
Sep 16, 2017 | Building Materials
Do i need an underlay for my plywood floor, and where do i start laying my bedroom floor
Depends on what thickness of plywood you have and what flooring you are going to put down.
Old school used 3/4" particle board over 5/8"plywood. ...particle board Is so susceptible to so many problems. It was called underlay as well as carpet pad and the pad under laminate or engineered snap together flooring systems. Sooo, need more definitive info to answer your question.
Oct 24, 2015 | Building Materials
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
How do i lay laminate flooring
Check out this video. Useful technique!
Feb 26, 2014 | Cell Phones
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
Can I install laminated floor in my bathroom?
Laminated floors can be used in any room you would like although there are some laminated floors that are more sensitive to moisture. If you want to use laminated floor in your bathroom you will need to prevent water from core material of the floor.
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
How much should I spend on a laminated floor?
In general, laminate floor will cost between 1 to 6 dollars per square foot, depending upon the quality of the design and its thickness.
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
How do I remove a hardwood floor polish safely from a laminate floor
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
Rotary RotoZip XB-LF5 Laminate Flooring X Bit  Logo
283 people viewed this question
Top Rotary Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
