Question about Broderbund PrintMaster Platinum Version 18
I have PrintMaster Platinum 12 that has been corrupted. I have repeatedly attempted to delete it so that I may reload from disc. Control panel does not permit me to delete it. Help please.
    Master:
  • 956 Answers
HAVE YOU REINSERTED DISC TO COMMENCE A SETUP?
A LOT OF PROGS USUALLY WHEN CHECKING SYS, ASK DO YOU WISH TOO REMOVE ASK DO U WISH TO REMOVE OLD PROG.
IF NOT, YOU WILL HAVE TO ACCESS PROGRAMS, FIND THE FILE/RIGHTY CLICK/REMOVE/IF FAILS/OPEN FILE/REMOVE WHAT DATA YOU CAN/RESTART/TRY SETUP?
Posted on Nov 15, 2009
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I cannot open my printmaster platinum 17 program. I have had this program for years and never experienced this before. When I attempt to open it all I get is a prompt asking "retry or cancel" I...
Sure - just use windows explorer and locate the documents you have in there. The files you created will have an identifier at the end such as " .doc " ".pdf" whatever.. Anyway, after finding them just transfer them over to a blank folder that you create making note of where you found them in the first place. Then uninstall the program, reinstall it and then put the saved files back into the same area you got them from originally. BTW, some programs when you uninstall them give you the option of not destroying files you created but with software I never take any chances!
Sep 19, 2017 | Broderbund PrintMaster® Platinum 17 Full...
Platinum 18 willl not open. Says I may need to reinstall printmaster and I am missing microsoft(r).network framework v1.1 Tried to reinstall printmaster and still doesn't work.
this is more than likely an issue witht the disc that the file is located on. I would contact the manufacturer and see if there is any way to get a replacement disc.
Apr 02, 2010 | Broderbund PrintMaster Platinum Version 18
I recently had my computer serviced for a major virus attack. System operates on Windows XP. I now cannot open PrintMaster Platinum 12. I get a message "cannot determine configuration." Additionally, I...
May have to uninstall it first, then reinstall it.
Click START button, lower left corner
then click Control panel
then click on add or remove programs
*see if your product is listed(may be under BRODERBUND or other publisher name)
If it IS listed, uninstall it
Or sometimes the UNINSTALL is included in the CD options:
Insert the cd into the drive
go to my computer
find the cd drive
right-click the drive
select "explore"
Look for an Uninstall program
Hope this helps!
hansola
Nov 06, 2009 | Broderbund PrintMaster Platinum 15 Full...
Missing disc
Hi mormonlady89
It's terrible when that happens...
Go to www.utorrent.com
download the program and install
then go to
http://www.torrentreactor.net/find/broderbund-printmaster-platinum
and click on the link and download the file and open with utorrent.
it'll take long but you'll get it non the less.
Apr 26, 2009 | Broderbund PrintMaster Gold 16 for PC
When I installed PrintMaster Platinum it caused Microsoft Home Pu
Uninstall Printmaster or right click on file to be opened and select open with, and in the prompt select "always open with..."
Nov 24, 2008 | Broderbund American Greetings Creatacard...
How do I uninstall printmaster silver 12
the question was regarding PrintMaster Silver 12, although it was posted in the PrintMaster Platinum 16 forum.
Anyway, Broderbund has the instructions on their web site
http://support.broderbund.com/fix.asp?isid=30284&print=0&prog=1294819732
Oct 18, 2008 | Broderbund PrintMaster Platinum 16
I have a error message when trying to open printmaster platinum 12
Use window search find the file and delete I did what was at support and it did not work I found this file in all users folder deleted it and all is well
Sep 05, 2008 | Computers & Internet
Broderbund PrintMaster Platinum Version 18 Logo
97 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
