Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How do i change windows xp to windows vista
I have never learned how to reboot a pc but i want to change my daughters windows xp on there pc to a windows vista how do i do this as i dont want to depen on people all the time
  • 233 Answers
I would not install windows Vista.
also your computer may not support windows Vista
event if it meets the minimum requirements, never go by that go by the suggested requirements.
hope this helps
thanks for your rating
Posted on Jan 09, 2008
Can't get the windows screen to come up on the computer only a blank screen with the cursor blinking in the top right hand corner. acer aspire one notebook
Change the boot sequence in the bios and let the windows be in the top drive, save changes and exit let it boot from the disk and follow the steps below
Do a repair of your XP installation.
•Boot from the XP CD
•At the Setup screen - Press enter (NOT R for repair)
•PgDn and press F8 for the Licensing screen
•Select the XP installed location and press R to repair
•Setup will copy install files and then reboot the machine DON'T REBOOT FROM THE CD. Let it boot from the hard drive.
•When it is done the process, remove the CD and reboot normally.
This applies to all os like win xp vista and win7
Feb 02, 2010 | Acer Aspire One PC Notebook
Changing from windows XP to Vista
If you are talking about Bernina artlink software here is a patch, but you nbeed to register. Check it out
Feb 25, 2008 | Bernina Artista 180
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
How do i rebbot my window vista xp laptob if I
If you have the CD that Came with the PC you can use that to reinstall Vista, All Dell computers ship with A dell reinstall disk
Nov 06, 2009 | Dell Latitude D520 Notebook
Cant install XP in my presario cq40 108TU
Delete all partition of harddisk and create partition again .
Then boot with disk.
Try this 2-4 times you done it.
If after 5 times still face issue then change winxp disk.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
I want update my compaq pressareo v410 pc desktop for windows xp & windows vista
Buy Windows XP from a reseller , insert into your DVD drive and reboot your laptop to get step by step instruction to install XP. AFter this do the same for Windows Vista.
Mar 07, 2009 | Computers & Internet
Acer orbi cam
Hmm well here are the directions to follow if you are using XP (as you mentioned at the end of your problem) it may also work when used with vista.
  1. Press ‘Alt + F10' to start eRecovery Management.
  2. Enter default password of 6 zero's. Example: 000000
    (Note: if this default password does not work, then a different password has taken its place. Acer is not responsible for any forgotten or misplaced passwords.)
  3. Select ‘Recovery Actions' and click ‘Next'
  4. Select ‘Reinstall Applications/drivers' and click ‘Next'
  5. On the left hand side of the newly opened window select the following: Windows XP
    ? Driver
    ?Camera
  6. On the right side of the same window, click ‘Install Camera Driver Now'
  7. The unit will reboot after the installation is complete.
Good Luck and dont forget to rate me!!
May 30, 2008 | Acer Aspire 3680 Laptop
Toshiba satellite 1955 S801 keyboard stop working...
What windows are you using? XP, vista, 98?
Mar 16, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
