Question about Mongoose Mischief 20 Freestyle BMX Bicycle
What is the thread size for the pedal crank spindal bolt that holds the crank onto the spindal
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
Sorry not sure on the thread size but any bike shop should have a bolt in stock
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 26, 2009
Looking for bicycle parts for DP Fit for Life AirGometer stationary bike. Need pedals
There are a few sizes of pedals that are standard. If it is one of these sizes , you can get the replacements at a bike shop , a hardware store ( True value , Ace , Etc . ) , or even a store like Meijers , or Walmart . The things you need to know are bolt size ( SAE , or metric , thread pitch , and is one a right hand , and the other a left hand thread . ) ( It is most likely metric , and one right , and one left hand thread ) .
DO NOT FORCE THE SHAFTS . IF THEY DON'T TURN IN EASILY , THEY ARE THE WRONG SIZE . IF YOU ATTEMPT TO FORCE THEM , YOU WILL RUIN THE CRANK SHAFT , AND NOT BE ABLE TO RETURN THE PEDALS FOR THE RIGHT SIZE .
Jul 13, 2017 | Pedals Cycling
Mongoose Ledge 2.1 pedal thread size
Measure the threads on the crank. Use or borow a pair of calipers. Measure with two threads as the outside edges to get proper diameter.
Apr 17, 2014 | Cycling
Assembly manual
To remove the crank (the arm the pedal is attached to), you'll need a special tool. I got mine at a bike shop. (Bike shops are our friends.) I use the Park Tools CWP-7. It's pretty much a big bolt with a smaller bolt going through it. You'll remove the cap covering the spindle bolt (if it hasn't fallen out already), remove the bolt that holds the crank are onto the spindle, then thread the "big bolt" part of the tool into the threads for the cap on the crank. You'll then screw the inside bolt into the big bolt, which will push the crank arm off of the spindle.
Dec 30, 2013 | Genesis Onyx 29" Cruiser Bicycle
The bolt holding the crank position sensor sleeve is stripped
get the next size larger bolt. get a tap that matches the teaed size and re tap the hole for the new bolt. Or if the threads are not completly gone,you can try red thread locker and see what happens. if that fails, then go to top of post.
Jan 31, 2013 | Cars & Trucks
What is the size of the bolt on the pedal, the thread on the pedal is damaged and will not screw onto the bike what do i do
If you are good, you can file the threads on the pedal to remove the damage and even reduce the size of the first few threads just to get the threads to start into the hole. Once the first few threads start in, the others should follow.
Dec 24, 2010 | Huffy BMX 20" Boy's Rock It Bike
What is the size of the thread of a standard bike pedal?
There are 2 standard sizes:
Standard one-piece cranks 1/2" x 20 tpi
Standard 3-piece cranks 9/16" x 20 tpi.
The Right Pedal (gear side) has a normal thread, the Left has a reverse thread.
Dec 21, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Left pedal broke can i get replacement?
All depends on if you stripped the crank arm, you may have to replace your crank arm if you rode with a loose pedal. Pedals are sold in pairs, and there are 2 sizes, a one piece crank is 1/2" and 3 piece crank is 9/16", take your bike to the bike shop and they will tell you if you need a new crank arm or not. It will do no good to just replace your pedal if there is a bad crank arm thread, it will not hold.
Sep 26, 2010 | Cycling
I need to remove the pedals of a Mongoose downhill mountain bike
Hi Miranda
You need to purchase a pedal removal spanner(wrench). They are very thin so they can slot in between the pedal and the crank.
If this is not an option, find a 15mm spanner(wrench) and tap it onto the bit where the pedal meets the crank. Ive always found that you need a friend to sit on the bike, hold the opposite pedal at the low stroke while you undo the pedal.
**REMEMBER** pedals have the opposite to normal threads. To undo them, you need to turn them clockwise. Spray penetrating fluid onto the threads a day before you attempt to remove them. They are very difficult to remove.
Hope this helps.
Aug 23, 2010 | Cycling
My left pedal is broken because it's really worn inside the pedal and I need to replace my pedals.
There are two thread sizes for pedals, make sure you get the right ones. Take the old one with you to the store.
You'll need a crank/pedal wrench to take the pedal off. The gap is too smal to get a normal size wrench in there, but you might get lucky.
Use some penetrating fluid on the thread and leave it overnight before you do it, as they are notorious for getting stuck on. Have a friend stand on the other pedal to keep it still, and undo it.
Tighten up the new one, remember the threads are backwards to normal tightening. Happy riding - vote for me please :)
Jul 02, 2010 | Wellgo 12 Crank Silver Bicycle Bike Pedals...
How can i take my pedals off
Since you did not indicate the the pedals were actually clips or special to your specific bike I can only assume they are standard pedals.
If you look where the pedal and crank arm meet you will see what looks like a metal pin. If you look closely you will notice this pin has two flats opposite each other. This is nothing more the a six sided bolt but with only two sides. Normally you would use a pedal wrench however a wrench of the appropriate size with a thin head will also work. Using a 2x4 about 4 feet long, place it against the pedal on the side opposite the side of the one your removing. Depending on whether you are loosening or tightening the pedal use the 2x4 as leverage against either the front or back side of the other pedal.
This will vary depending on the type of pedal you wish to remove. For instance some pedals use an allen head bolts that is threaded in from the inside of the crank arm.
Hope this helps.
Oct 07, 2009 | Pedals Cycling
Mongoose Mischief 20 Freestyle BMX Bicycle Logo
245 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
