Question about Ovens
GE WPSR3120WOWW FIRST WASH WORKED AND DID'T FILL BACK UP WITH WATER FOR THE SECOND WASH AND THE SPIN CYCLE WON'T WORK.
  • 1,543 Answers
Pop the front cover off by using a putty knife to push the clips in (2) at the seam where it meets the washer's top. Pull the thin hose off the left side of the tub and clean it out. (do this with the tub empty) replace tube and front panel and you are good to go.
Explaination: The goop in the tube prevents air from escaping as the water level droped, thus the washer thinks it is still full of water. If it thinks it is full of water, it will not fill any more, nor will it spin.
To prevent this from re-occouring, I'd suggest filling the machine to the lowest level with hot water and adding several cups of bleach. Run the cycle (with no clothes) to help clear out the goop. Use an extra large rinse to make sure there is no bleach residue before doing a load of clothing again. Do this about once every 3 months, and I don't think you'll see the problem again.
Posted on Nov 15, 2009
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My frigidaire oven wont stop beeping and it has a f9 code
    Hi
    F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
    Daniel
    Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
    I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
    Hi
    Daniel
    Aug 07, 2011 | Maytag Ovens
    OVEN WILL NOT COME ON AND IT DISPLAYS F9. WHAT DO YOU DO?
    Hi
    Daniel
    Aug 02, 2011 | Amana AOCS3040SS Electric Single Oven
    I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
    Hi
    Daniel
    Aug 01, 2011 | Amana ACB6260A Electric Double Oven
    He4 tub won't spin. It fills with water and drains out but wont spin
    Hello cnt.... If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    Dec 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    F2 error
    F2 is a bad temp sensor, needs to be replaced.
    Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
    F2 error
    what is solution
    Dec 08, 2007 | Ovens
    Ovens Logo
    176 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
