Question about Lavazza Espresso Point Capsule Machine
Our machine is not dripping the coffee into the cup but is dripping water into the basket and is missing the cup
    Problem Solver:
  • 19 Answers
You need a tune -up estimated costs about 175.00 contact me www.lavazzarepair.com
Posted on Dec 11, 2009
Cuisinart Brew Central 12-cup Coffee Maker Filter Basket Anti-dripo has come unattached. We have a spring and the anti-drip puiece. How do they go together?
Hello tfsmithcambr,
You need 3 pieces. The bottom plug, the spring, and the collar. Slip the spring over the plug. Insert the plug into the basket end. Slip the collar onto the inside the basket end of the plug shaft until it clicks. Should be good to go. If this does not work or you are missing a piece, you may need a new basket. Hope this is helpful. Good luck and kind regards, NormanZ
Jul 07, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee maker with grinder--sometimes, when percolating, it overflows
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Jun 23, 2009 | Mr. Coffee TFTX85 Coffee Maker
Coffee grounds overflow out of basket into top of coffee pot.
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Jun 11, 2009 | Bunn 10 Cup Home Coffee Brewer
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Cusinart 12 cup grind and brew overflows with grinds and water
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Need owner's manual for a West Bend 57870 coffee maker
Manual Not Listed On Website, but Information on Coffee Amount is.
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2318&secid=54&linkon=category&linkid=21
Coffee Amounts
How much coffee should I use?
4-Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. You can adjust the amount to suit your personal preference but DO NOT USE MORE THAN 2 TABLESPOONS per cup being made. If more than 2 tablespoons per cup are used flooding of the basket may occur.
10 and 12 Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. If making less than 4-cups of coffee, add an extra tablespoon of coffee for better flavor. You can adjust the amount of coffee used to suit your personal preference.
Dec 28, 2008 | West Bend 56870 Coffee Maker
Water overflows from filter basket
Dec 25, 2008 | Mr. Coffee ISTX95
Water/grinds spillover in coffee basket
Pot must be inserted with the handle pointing straight out the front so it will hit the valve that is below the basket designed for the "rob a cup" while brewing feature.
Calvin
Aug 13, 2008 | Coleman 5008C700 Camping Coffee Maker Free
Lavazza Espresso Point Capsule Machine Logo
282 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
