Question about Toshiba Satellite A105 Notebook
Toshiba Satellite A105 lcd display
I have a problem with my display on my lcd screen. I can faintly see my start up window but I believe my backlight button maybe stuck but can't find it on this model. Can you help me out?
  • CeCe8 Jan 09, 2008
    Unfortunately, I tried that solution already along with the Fn F5 solution and neither is working. In my research, I found that the problem may be that the backlight button (which is usually a small plastic button by the hinges) is stuck but for the life of me I can't find that button!
  • JennyNi Oct 14, 2008
    I have the same problem. So how can I turn on the backlight?
  • 4 Answers
It's the LCD inverter, it's like the started circuit for a flourescent light that makes your backlight work.
Can be purchased online from a bunch of places.
Then remove the rubber stops and the screws from around the screen, CAREFULLY pry the bezel away from the screen and you will see the inverter at the bottom of the screen.
NOTE: This also applies to laptop screens that turn pink or red and ones that go bright and dark ar random. A good 85% of the time.
Cheers
ozmont
Posted on Oct 15, 2008
The Satellite A 105 does not have an external switch to tell the laptop that the screen is open or closed. Instead there is a magnet in the uper right corner of the screen trim. This magnet activates a switch hidden in the laptop.
I have the same problem. I believe I found the problem. I don't know what you call it, but I believe on my laptop, the backlight starter is bad. I can't get any voltage out of it.
If you want to test the switch, you can change your power settings so that the computor goes into standby when you close the lid. Then when you close the lid, if your laptop hibernates, you know your switch is working.
Posted on Feb 02, 2008
  • 45 Answers
keep typing the combination of "Fn" and "F7" on the keypad .
note: you can find "Fn" on the lower left of the keyboard and "F7" on the topmost right of the keyboard...
Please let me know the results...
Thanks
Posted on Jan 09, 2008
Are all Satellite A105 15.4" screens the same? I
The LCD assembly will have a part number either on a paper sticker or printed on some empty real estate. Check for one that matches the structure of part number(s) listed on eBay.
You can start with the link below:
Toshiba Satellite A105 LCDs
Aug 07, 2011 | Toshiba Satellite A105-S2716 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Display
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
May 09, 2009 | Toshiba Satellite A105-S4004 Notebook
LCD dark with white vertical line down it
It is the C-Board Panel Attached to the Display Panel And Is Integrated into the Screen .. You will need a screen replacement..
Your part is.... Toshiba Satellite A105 15.4" LCD Screen LTN154X3-L06
Feb 13, 2009 | Toshiba Satellite A105 Notebook
Display
If you've got exacttly the same each time you're start, then the VGA card has issue, or even the motherboard and CPU.
If not then try to chock the base of the screen with two fingers when starting, if nothing happen try to chock the middle of the keyboard and several spot around it. (it's a little bit brutal but the easiest way to find a bad contact or dead components)
If you feel like open it then this website will help you:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
and for the screen:
good luck
Dec 16, 2008 | Toshiba Satellite A105 Notebook
New lcd screen displays four session of windows
try going to conecting an external display in the mobility center and set it to mirror your laptop
Nov 11, 2008 | Toshiba Satellite A105 Notebook
LCD Display problem
THE WIRING OF UR SCREEN IS DAMAGED GET IT REPAIRED BY A PRO
Nov 24, 2007 | Toshiba Satellite A105-S4004 Notebook
LCD display problem
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Oct 19, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba A-105 Satellite, LCD Screen problem
when you "adjust the angle of the screen", that can only be a faulty electrical connection. Try again at the mainboard connector.
Jun 04, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
1,334 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
