Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
I cannot turn off the SAP on my Sony tv, hence I have NO volume. I tried everything using my remote control. Is there some way to reset??
Problem resolved, I was able to borrow another Sony remote and made the appropriate adjustments.
Posted on Nov 17, 2009
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
My sound on the TV just went about a week ago and i cannont get it back for some reason. Everything else is perfect so I dont know what is wrong with it?
Check your TV may be set to Auto SAP in the MTS feature. Make sure the speaker option is set to On in the Audio Menu. Or Reset in Factory setting> Turn on the TV. While holding down the RESET button on the remote control, press the POWER button on the TV front panel.The TV will turn itself off, then back on again. Release the RESET button.
Jun 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My wife was hitting buttons on our satellite remote and the audio no longer works. She thinks the tv is the problem. I have tried all of the Satellite volume menus and am unable to get the sound back on.
TV: check for SAP or MTS features, set them to STEREO. Also, verify that the TV Speakers are set to ON.
Cable Box: If the box has volume controls, make the volume is turned up. Also, check for the SAP or MTS feature. Again, set this to STEREO.
I hope this was helpful, best wishes.
Jun 12, 2010 | Televison & Video
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
Dec 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have an audio problem LC-26d43u
What's "everything"?? Have you looked at the audio menu to see if you were on SAP (second audio program).. Being in SAP could affect one or more channels that do not broadcast in SAP mode.
Bill
Nov 13, 2008 | Televison & Video
No sound, No more
Sorry it took so long to reply, to your request for help. You need to use you owners manual and go to the section on audio controls. Check every function that can turn off the volume to the television while it is playing. Make sure all the controls are set properly for the use of the audio on the television. If you cannot find the problem and correct it this way, you can call the RCA customer support telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for their assistance. I hope this information helps you with your remote control problem. Thank you for using FixYa and have a nice day!
Oct 26, 2008 | RCA DIRECTV Satellite Remote Control
Sound isn't working correctly
Hello dotdeb99, Use your remote to go to the menu on your TV and scroll through the menu items, you should see the SAP feature. Then turn it off. You can also get the users manual for your TV on-line and it should have SAP instructions in it. Just remember SAP is a TV menu item, it will not be actually on the remote itself. Thank you.
Sep 05, 2007 | Sansui DTV2760 27" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
565 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
