Question about Bosch WFMC 3200 Front Load Washer
Where do I put rinse aid in my Bosch Classixx dishwasher?
  • Bosch Master
  • 3,463 Answers
You put it in the smallest of the 3 compartments.
Please rate my solution.
Thanks.
Posted on Nov 15, 2009
When the wash is complete the items are still wet and so is the inside of the dish washer have tried different temperatures but same problem have also left washer closed all night after wash has finished...
Either the heater unit or the dryer fan is faulty.
Check that you have not been using the Eco wash cycles.
Also make sure you are using the detergent and rinse-aid recommended in the dishwasher manual.
May 22, 2011 | Bosch 24 in. SGS43C02 Classixx Built-in...
The salt and rinse aid lights stay on
Top up salt and rinse aid or just ignore the lights if you use 5in1 tabs.
Apr 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishes are coming out streaked and not properly cleaned. I have added rinse aid, salt and even descaler.
De-scaler wont wash your dishes. The simplest cause of dishes coming out unclean is over-loading, bad stacking (spray arms blocked), or using too short a programme for heavily soiled dishes.
If it's just streaky (not food remnants), you may have the rinse-aid set too low. Open the flap where you add rinse-aid and you will see a know with an arrow shaped grip. There are 5 positions for the knob marked 1 to 5. Try a higher setting (1 is low) but don't go too high as this will cause other problems. If it's on 1, try 3 and if it's on 2 or 3, try 4 or 5. You may have to adjust this a couple of times until you get satisfactory results.
Howver, If you're referring to a white powdery residue on dishes and glasses, that's an entirely different answer . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Machine wont empty properly pump seems to work. machine sounds like its operating normally bosch classixx dishwasher
dont use soap with jet dry or rinse aid in it. use regular cascade soap and fill completely with jet dry rinse agent. your unit is over sudzing .if this is helpfulto you send me a 4thumbs up post
Feb 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Door is wet with condensation at the end of the cycle although dishes are dry
this problem should be under dishwashers not washing machines! however this is caused by lack of rinse agent this aids the drying process and removes moisture from crockery check levels if ok try using detergents with salt and rinse aid combined may be dispenser is not working properly.
Sep 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
HOW TO PUT RINSE AID INTO THE DISPENSER CORRECTLY???
if you're referring to rinse aid for a dishwasher, just unscrew the dispenser lid, and fill the dispenser with rinse aid, then screw top back on.
Mar 22, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch WFMC 3200 Front Load Washer Logo
735 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
