Question about Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Posted on Apr 09, 2010
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
Nov 18, 2011 | Maxon 49-SX (1 Channel) 2-Way Radio
We bought two Maxon S1 walkie talkies. They do not work. We have tried all the channels (1-8) and several privacy options, but even at ten metres we cannot communicate. Sometimes voice comes through but...
I had the same problem. Take your radio to the professional service. One was ok, but the second has problem with frequency keeping. They shown it on a scanner. The second problem was settings. The output power was set 25 mW, and the band was set wrong to the long range communication. Only professional service can fix it.
May 09, 2011 | Maxon TK14-1B (14 Channels) 2-Way Radio
MCB 30, frequency
40 chanel CB operate from 26.9650 to 27.4050 mHz.
That is an AM rig
Mar 25, 2010 | Maxon MCB-30 40-Channels Base CB Radio
What frequency do these run?? am or fm??
CB or citizen's band is in the 27 MHZ band. Its 40 channels long, AM typically, and on some models side band, or SSB.
It is only legal in the US to have a radio that operates in the 27 MHZ band on the designated 40 channels using AM or single side band only.
The MCB-30 is an AM only radio.
Hi i have a maxon Radio i am not sure what model it is as it does not say the model. I was wondering how i would programme the radio so that it would work on a certain frequency
if it is a CB radio, you are stuck on the 27mhz band, and the channels that it comes with. I am not familiar with maxon radio's. Some radio's the PLL chip can be controlled to shift the band the radio works on. This is still limited to the 10-11 meter bands. You can go a band up, and a band down usually.
I have no clue if this radio is capable. So I couldn't tell you how to do it.
I can tell you, that you cannot just pick a frequency and make it work on it.
Oct 24, 2009 | Radio Communications
Maxon SL25
if the band assigned to the radio doesn't cover the frequencies you want then it will not happen. you need to get the software and the right programming lead. make sure the mic socket is good and clean
Nov 19, 2008 | Honeywell Maxon SL25 Two-Way Radio Battery...
49-F5
Your M/C is generating RF(radio frequency) energy from the electrical system. I wish I could tell you exactly where the problem is but there are to many places that could cause this problem. some possible problem areas are the alternator, spark plugs etc. You might consider upgradding to a set of newer radios. this may be cheaper than trying to figure what area of the M/C is generating RF Energy
Aug 28, 2008 | Maxon 49-HX 2-Way Radio
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
SL55 Not Transmitting/Recieving
the two radios are on different CTCSS Tones
Feb 01, 2008 | Maxon Radio SL55, SP130, SP140, SP150...
Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery Logo
713 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
