Question about Krups Small Appliances Espresso Machine
I have an error code 0C on my EA8080 machine. what does it mean - do I really have to send it back for repair?
What is error code 6 on krups ea850b10 means?
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Aug 03, 2015 | Krups Small Appliances Espresso Machine
Error code 5 on Krups ea8080
During the first few seconds of pump running there is zero water flow. Either there really is no flow at all OR the flow meter is not detecting flow for some reason.
Oct 19, 2014 | Krups Cafe Express FMA110 Coffee Maker
Machine fault error No 0C
0C
Faulty communication between the 2
boards
Disconnect and reconnect the
coffee-maker
Overconsumption on low voltage power
supply: Distributor blocked, does not turn
Determine the cause
Dec 16, 2013 | Krups XP7230 Compact Super Automatic...
Machine is ready the get copy but error code E000531-0000 is show on screen
This means that the stapler isn't moving properly in the finisher. This error code is not really a do-it-yourself solution, so you will really want to have someone come and repair it for you. In the meantime, you can probably make the machine usable by turning it off and back on to reset the code, then avoid using the stapler until service arrives.
Feb 28, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
What does code f1 mean
Hello
Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Brother MFC-5890CN also shows a message "Unable to print 36"
Machine Error 36 means just what said, either mechanical problem (not very likely due to age of machine), or loose part. Most often caused by ripped paper or a paper jam which results in a moved/smudged sensor, making the machine alarm.
But since the error can be temporary removed, it should be something loose that gets in the way when the printer head moves. Unfortunately, most likely the solution will be to have it serviced.
The error isn't unique for this model, but is an error used on almost all inkjets from Brother the last 4-5 years. Unless you really can find anything loose (or possibly help cleaning some with compressed air) you will have to send it in.
Jun 05, 2009 | Brother MFC-5890cn Color Flatbed...
Message codes on Model 28871
I think what you are saying is actually St. It just means you need to set the time on the answering machine. We got stuck on this too.
Jul 14, 2008 | GE Cordless Phone & Answering Machine...
Error code meaning
this errror not related to psu section.After repairing this error occurs means its ncu or m.b. not properly packed, where machine last repaird send to that service centre check with this problem.
Dec 27, 2006 | Panasonic KX-FHD331 Plain Paper Thermal...
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Krups Small Appliances Espresso Machine Logo
211 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
