Question about Qca Spas GT 454 Hot Tub
Looking for older manual for8 button qac majestic spa cntrol can you tell me were to get this
    Problem Solver:
  • 8 Answers
What specific question do you have? The manuals really only go through alot of obvious functions, but the error codes are interesting to note in case a problem occurs. If you have anything you want to know about the spa, ask away...
Posted on Apr 10, 2010
  • 366 Answers
This is the only one available online.
http://www.qcaspas.com/content/pdf/Majestic-10Btn.pdf
Posted on Nov 15, 2009
How do you get it off economy mode
there is a MODE/PROG button on the panel. this buttom switches the unit between the modes.
Press it and it will cycle thru from Standard to economy.
It's on page 5 of the manual... and you can download it from http://www.qcaspas.com/content/pdf/Majestic-10Btn.pdf if this is your unit
Jun 29, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Need diagram on how to thread a majestic sewing machine made around the early 1950's
I have a majestic also and I have the original manual. I can send you a copy if you will post your email. I am not a spammer.
Oct 16, 2012 | Sewing Machines
HAVE A 2001 STANDARD SERIES POWER TO SPA BUT NOTHING COMES ON
I was just wondering if anyone knows how much water the QCA Majestic Spa holds ???? It doesn't tell you in the directions!
Sep 06, 2012 | Qca Spas Dream Series Dream Master Hot Tub...
Flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Unlock control panel
Press & Hold the JET Button for 6 seconds (Most/Gecko & Hydro-Quip)
or
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Apr 16, 2011 | Qca Spas Majestic Series Aruba Xl Hot Tub
Every time the pumps shut off I get a FLO code. Where do I find the flow switch
That is just telling you that your heater isn't working because you don't have flow. This is because your pump is off.
Nov 26, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Spa went over set temperature with loc message
How far over the set temperature did the hot tub go?
A hot tub may sometimes exceed the set temperature slightly especially if it's well insulated and has been on a long filtration cycle.
'Loc' usually means that the keyad is locked or partially locked. Check your quick reference guide and it will tell you how to remove the keypad lock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Where is the drain on the Aruba Majestic Hot tub? I have never drained the tub and would like to keep it empty for a few months before refilling
the drain is located on the very lower left corner of the tub. (lower left is decribed as where the control panel is at the top, look at the bottom to find the plug and insert a hose to keep the water flowing away from the tub.
Oct 10, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Qca Spas GT 454 Hot Tub Logo
173 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
