Question about Car Audio & Video
I have a leus is200 and dont no how to load a cd into the cd unit i press load it makes a noise then nothing happens it doesnt take the cd
    Scholar:
  • 60 Answers
The Lexus CD players go bad quite often. You can take it to the dealer and they should fix it for free if its still under warranty.
If you have some CDs in there that you want to remove first, hold the eject button for 5 seconds they should all come out one at a time.
Posted on Nov 15, 2009
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
Jan 11, 2014 | Acer AL2216W LCD Monitor
Scraping noise coming from front passenger side of lexus is200 sport drives well with no other noises only when turning steering wheel from parking position
Am sorry to inform you the advise your getting about a cv joint is wrong as the is200 is rear wheel drive it dont have them
Apr 27, 2012 | Cars & Trucks
Six disc changer will not play, eject, or load. making eject noise nothing happens.
it sounds like the photo sensor has failed this unit detects disc and loads them if it blows it thinks it has a disc and will try to eject it over and over
time for a new stereo sorry
Jun 25, 2010 | JVC KD-G110 CD Player
Making noise???
If it happens right away on the spin only setting, sounds to be something clogged in the pump....common things bra wires, hair pins, nails, screws..etc. Only way to access the pump is from the rear of the unit reaching through to te front....pain in the but to techs...I'd suggest if it makes the noise and drains slow to have a tech come out and fix your problem....but if you want an adventure unplug unit and empty the water, take the rear panel off and remove the hose from the tub(screw clamp) and reach inside with your fingures and see what you feel...may need to take hose completly off. reassemble and test with an empty load...fill with water and drain...be sure to check for leaks afterwards
Jun 10, 2009 | Frigidaire ATF6000ES Front Load Washer
My hp jet scanner 6200c doesnt scan.
I lost the CD of the hp jst scanner 6200c, but i down loaded the program on line. However, when I scan nothing appears on the screen and the scanner makes a lot of noise. The light does go on on the scanner but it doesnt scan i get a blank
Nov 22, 2008 | HP ScanJet 6200C Flatbed Scanner
CD wont load in laptop
the cd-rom drive is bad. you need to replace it
Apr 17, 2008 | Computers & Internet
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
Cd drive
Try having your cd drive cleaned. A cd drive could prevent the cd drive to read the disk properly. The drive noise is normal if the speed of your cd drive is high. Here are some links on how to clean a cd drive:
http://www.deinmeister.de/cdrep_e.htm
http://www.ehow.com/how_2044857_clean-cdrom-drive.html
Here is the link for reducing the speed of the disk (if the sound annoys you):
http://hektor.umcs.lublin.pl/~mikosmul/computing/tips/cd-rom-speed.html
Nov 22, 2007 | Sony VAIO PCV-RX462DS PC Desktop
Load problem and error message
Did you try to reset it? Look for a small button that only be press with a toothpicker or something that small. Another way to reset is to disconnect the battery. Goodluck.
Sep 30, 2007 | Alpine CDA-9856 CD Player
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
