Question about Nokia 3110 Cellular Phone
There is small lines start to come out then number has increased
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
Ryobi line trimmer plt3043a starts idles but dies when i attempt to increase speed
May I suggest checking along the fuel line and its attachments for a very minor air leak. The minute it sucks air it will stop. Check any rubber washers or O rings too.
Feb 02, 2015 | Ryobi Garden
Vacumm lines
vacuum line schematic should be on the rad support under the hood to locate the leak, buy a small bottle of propane put on the nozzle but don't light . as you pass the propane over the leak the revs will increase . you have found your leak
Feb 26, 2014 | Chevrolet 1500 Cars & Trucks
Explain the steady increase in the number of lines of symmetry in the square, hexagon, octagon and circle shapes
Please don't ask me to do your homework-you are going from 4 lines square-8 lines octagon-infinite number in a circle-cheers Denny
Oct 08, 2013 | Symmetry Tires 43086 P205/65r15 92t Bsw
How do I INCREASE the size or my fonts
Hi lingene...
I have to assume (because you did not say) you want to increase your font size in your email program.
If this is so (and your using hotmail as I am) you will start your email...when the program opens look to find a small pair of sissors on the page...in that line you will see the sissors,font name,and font size...click on font size and change the size of the font to the size you want.
The larger the number the larger the letters will be.
If this is not what you want please re-submit your question with the right program you want to increase your font size in.
Please take time to rate me
Sep 06, 2011 | Computers & Internet
Sewing basic stitch is good on right side of fabric but looks like a wavy line on reverse
Hi. Chances are your upper thread tension may need to be adjusted, increasing it by very small amounts at a time (say one tenth of one whole number), see if the stitching on the bottom improves. Another possibility is that the bottom fabric is moving around. Try pinning top and bottom together with straight pins set at a right angle to the stitch line. A third possibility could be lower thread tension set to tight. If the lower tension screw is all the way in, this is likely your problem.
Aug 19, 2011 | Vacuums
Down the left hand side of my monitor a column of mishapen small horizontal lines are slightly visible when the monitor show slight colours . they are harder to see when it displays white how can i fix...
Assuming that you have tried the monitor on a different computer and that the pins on the VGA lead show no damage or signs of looseness and that the vga lead is a good fit in the socket, the probable answer is that the monitor is starting to fail. Eventually, the lines will increase in size, or in number and will be more visible. Repairs are usually not worth the cost of buying a replacement monitor instead. My advise is that if you can live with it, thendo so until you decide to get a replacement.
Jul 15, 2011 | E-Machines E17T4 LCD Monitor
Was just wondering when doing a compression test on motor..what the numbers should read....and also what should they read when testing a new motor?
The standard compression for your honda would be around 175 psi the minimum would be around 135 psi. they should be the same new or old engine. and there not the same for all engines
Sep 30, 2009 | 1989 Honda Prelude
SCX-4200 cannot make multiple copies
I believe on this unit that when you increase the # of copies, you have to press the set or enter button to accept the amount, then press copy. Most small Samsungs are like that.
Jul 01, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Increasing water flow rate
Back-flush the machine regularly and check your water hookup and make sure you to not have a small diameter water line. Other than that it is controlled by the water pump I believe. If the solenoid (the silver thing attached to the pump) used to start the pump is old it could slow down the pump start cycle.
Jul 01, 2007 | Rancilio S24 Espresso Machine
Nokia 3110 Cellular Phone Logo
13 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
