-   I unable to login into the modem , And even I reset my modem I am unable to login. I have tried all possiblities Kindly suggest
-   Guest
Feb 07, 2008
-   We have one of these as well that someone has set the login and password on - it's a Verilink (Prism) T-1 3111 CSU. We're trying to find a way to reset it back to factory defaults or get in on POST. No luck so far.-   Guest
Try looking on the modem itself, sometimes they have their default username and password written on them.
Try combinations of "user" or "admin".
eg username: "admin" password "admin"
if these don't work and you don't know why you can't log into your modem, try resetting your modem using the reset button on it (or holding the power button for 10-20sec) and then try the above suggestion again.
If you still can't login, write back with your modem make and model number.
Comments:
Jan 09, 2008
- Just to be sure - we are talking about your modem, not your computer, correct? The reason I ask is you mentioned the monitor having the model number.
The modem itself should have a name like alcatel, or motorola written on it. I need to know more information before I can help you
will vmmi version 17.11.06 D work for programing from my laptop on a FXII. I am worried there is a...
(More)
will vmmi version 17.11.06 D work for programing from my laptop on a FXII. I am worried there is a newer version that I need for this to work.
I have a Canon MF6550 and it has been great until now. We recently switched from analog lines to...
(More)
I have a Canon MF6550 and it has been great until now. We recently switched from analog lines to intergrated T1 with a PRI(23B+D). Now our fax will receive but not send faxes. Any suggestion as to what settings I could change for fix the problem?
my modem will no longer recieve faxes it says a fatal error has occured but it will still send faxes...
(More)
MY MODEM WILL NO LONGER RECIEVE FAXES IT SAYS A FATAL ERROR HAS OCCURED BUT IT WILL STILL SEND FAXES FINE. I AM USING WINDOWS FAX CONSUL ENABLE SEND AND RECIEVE ARE CHECKED
hi i have a sb5101 that has haxoware in got it done last week now have 2 lights on how do i get into...
(More)
hi i have a sb5101 that has haxoware in got it done last week now have 2 lights on how do i get into it to change firmware a friend done it for me but he is in scotland am in liverpool
