Question about Yamaha RX-V10 Receiver
Power shuts down after 3-5 minutes.. What is causing this..?
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
When i plug my dvd writer to the power supply it keeps causing my computer to shut down and start back up then shut down again
It has gone faulty and is causing a power overload and this causes the PC to shut down, so it will not be damaged. Either the power supply Inside the DVD is faulty or the DVD, is.
Feb 27, 2010 | E-Machines eMachines Desktop PC
IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
Power failure
your laptop may become overheated and that is why it shuts down, make sure the laptop is on a hard service so that the fan can get air. hot weather can cause problems as well.
May 28, 2008 | Toshiba Qosmio G25-AV513 Notebook
Just shut down
The player has a sleep timer - change the auto shut-off option 180 minutes or so - it will only shut off every 3 hours in that instance - read your manual for more specifics
Dec 23, 2007 | SanDisk Sansa e250 MP3 Player
Yamaha RX-V10 Receiver Logo
19 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
