Question about Sony Playstation 3 (PS3) Console
PS3 Games load and then freeze.
Appears to be spinning (RPM) excessively after 3.01 upgrade. I get the following errors:
Error Codes along with what they mean:
80010514 - Possibly reading blu-ray disc problem
8001050F - Hardware failure. Cannot update firmware or connect to internet.
80010510 - Will not play games installed on the hard drive
  • 393 Answers
Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
Does this affect me?
-If you have a Slim PS3, you’re good to go. Continue playing it as normal.
-If you have a “fat” PS3, you may be affected. Some fat PS3s have worked ok, but it seems a good majority have been bugged.
What does this bug mean?
-If affected, your date and time has been set to a random past date. This prevents you from signing into PSN, playing any PSN games, or using any DLC. Your trophies will also not display correctly or be able to sync.
How do I fix it?
-You can’t. Even if you don’t sign into PSN, it won’t help. This is a hardware issue.
So, what do I do?
-Wait 24 hours. Other products that have had similar bugs have corrected themselves after the “bugged” day. On Monday around 6pm central time, all PS3s will automatically correct themselves…maybe.
-If that doesn’t work, we’ll need a firmware update from Sony, which should be a pretty important priority for them right now.
Did I lose my data/themes/etc?
Your save data/games/dlc/themes are fine. They’ll be fixed when the PS3 is fixed. Trophies are uncertain right now, but they’ll be fine if you’ve synced them before the PS3 was bugged. Unsynced trophies are an unknown right now.
If I have a bugged PS3, can I still use it?
It’s probably not a good idea, as I have no idea what will happen to the trophies you earn during the bugged time. Movies/media will work fine.
sdfsdfsdf
Posted on Mar 01, 2010
When i go on the game it always has a tick on a ps3 and the game doesnt load up and it says (80010516)
Most of the time this error is caused because you eject games while they are being used. To solve this error try the following in order, one by one, until your problem is solved.
1) Turn your console off using the switch in the back.
2) Delete all your messages.
3) Clean the disc for the game that is causing the error.
4) Upgrade your PS3 Firmware.
5) Turn "PS/PS2 upscaler" off.
If not of that works, your disc is broken.
Mar 10, 2011 | Sony Playstation 3 (PS3) Console
PS3 error 80010017 or game will start up but finish loading
Easy fix :)
Go into Account Management ([Friends] [Account Management]), de-activated and activated again.
If this does not work, then your HDD is corrupt.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Upgrade to ps3 firmware 3.01 and now it won't play games.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
Lets sum it all up, the error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
GTA 4 FATAL ERROR: RESC10
If you are trying to run it on a PS3 console, Try to upgrade you'r PS3 console
Aug 03, 2009 | Rockstar Games Grand Theft Auto™ IV for...
My ps3 gives me two error: 80010514 and 8001002B, I tried it all.
go under settings then system settings then restore default settings
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
My PS3 freezes up shortly after start of game, won't run movies
I believe you may have little or no memory left...
you can upgrade it with a 500 Gb HDD from SATA (2.5' 8or 16" MB Cache make sure it is 5400 RPM ) You can buy it at best buy..
I replaced mine... and it works great now.. when you replace it you can download the software into your external hard drive and transport it back into your ps3..and itll instantly upgrade it for you
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 games will not load and get checking HDD error message. Playstation said it was a media loading problem. Did it overheat? Any ideas? Thanks
This is a ps3 laser problem it is mainly caused by prolonged spinning of the disc whilst the game isnt bieng played i.e paused for more then 12 hours. contact me for more info. t_cooper21@hotmail.co.uk
Dec 01, 2008 | EA Sports MADDEN NFL 08
My ps3 wont load games or it freezes when it turns on
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Aug 31, 2008 | Sony Playstation 3 (PS3) Console
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Sony Playstation 3 (PS3) Console Logo
209 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
