Question about Quinny Buzz Jogger
We are trying to collapse the frame we have no clue how to fold it ready for car.
  • 419 Answers
If you lock the front wheel and lower the handle bar to the lowest postition first, this will make the chassis as small as it can be. Remove the seat/car seat or carry cot if this is on the chassis.
Then, stand in front of the chassis, with the front wheel between your legs.
Push down the grey rectangle button on the left hand side, then pull toward you the right hand rectangular button then push this button downwards,
Then, withnthe two buttons still pushed in, with your full body weight, push the chassis downwards the floor until fully folded.
I hope this helps.
Posted on Nov 15, 2009
Where can we get details about bi-fold aluminum ramp?
There are numerous internet sites on the internet which can be offering info in relation to bi-fold aluminum ramp. These are especially made for those people who are trying to find quality lightweight aluminum collapsable ramp. to learn more check out this amazing site :http://targetmfg.com
Nov 21, 2016 | Cars & Trucks
Quinny buz won't collapse
Hi
We wouldn't advise anything apart from cleaning the chassis, as a build up of dirt and debris on the chassis would cause friction and make it difficult when trying to fold. Clean with furniture polish or dry Teflon spray and a soft cloth - don't use an oil based lubricant.
Other than that we'd recommend you contact the customer care team at crelations@djgusa.com for assistance.
Jun 21, 2012 | Quinny Buzz 3 Travel System Baby Stroller...
Hello, I recently bought a quinny buzz 3 (second hand) and its very difficult to collapse the frame, but it's easy to open it back up. What would I need to do to fix the problem?
Good Evening
It sounds as though you're not quite depressing the fold buttons fully when trying to collapse it, so you're pushing against the natural spring of the chassis which is making it difficult.
The Buzz is easiest to fold when you're standing in front of it. Either remove the seat unit, or make sure it is forward facing and in the upright position before you start. Swivel the front wheel straight and lock it into position. Standing in front of the Buzz, push the left side button in until you can't make it go any further, then roll the right button toward you as far as possible. It should only require a small amount of pressure to fold the unit, but remember, due to the style of the automatic unfold you are working against it to fold it up. If you hear any clicks, pops or creaks, don't force it as you'll break the fold knuckles.
If this still doesn't work, give the chassis a good, thorough clean to make sure no dirt or debris is causing the problem. Use a dry Teflon spray (found in the laundry aisle of most supermarkets) or normal furnature polish with a soft dry cloth and give the whole chassis a thorough cleaning. Then as you're folding it down, follow the black plastic down the central tube as it goes toward the front wheel unit to make sure its totally clean. This should make it smoother to fold.
Failing that, the product will need to be returned to the engineers for inspection - which country are you in?
May 18, 2011 | Quinny Buzz Three Wheel Stroller
How do you collapse the little tykes picnic table?
Flip over the picnic table and have a screw driver ready. There are 4 "braces" screwed into place to ensure the picnic table does not collapse on your children.
Once the braces are removed, you should be able to apply just a bit of pressure and fold the picnic table down flat.
Sep 29, 2009 | Little Tikes Fold and Store Picnic Table
How to fold the Graco Stroller 6001BCL1
Take the carrier off by raising the handle and then lifting the handle with one hand as you pull the red handle on the back of the carrier with the other hand. Set the carrier aside and stand behind the stroller. There should be 2 matching plastic 'things' on either side of the stroller, just under the rubber handle. Put your thumbs on the rubber handle and your first 2 fingers on those plastic pieces. Pull those plastic pieces up with your 2 fingers and the stroller will collapse. I hope this helps!
Sep 26, 2009 | Graco Baby Gear
How to fold stroller
i have both the double and single dreamer design stroller and on both - there is a black pull thingie ... if you put your hands on the handbar and then follow down the frame (along the back side of the seat). You will feel it - as it is kinda hard to see. Once you pull this on both sides, push down on the handbar - towards the ground. The stroller will then fold down and in half.
Aug 18, 2009 | Dreamer Design Ditto Manhattan Twin Seat...
Does anyone know how to fold/collapse a triple stroller for easy storage? Does each seat have to be removed before you can fold the frame? Is there a user manual that I can review? Any help would be much...
You have to remove each seat before folding it,you can call perego at 1800-671-1701 they will send you one for free or go to www.pegperego.com to get one.
Jun 15, 2009 | Peg Perego Triplette Stroller
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
Closing it
You need to push the red buttons underneath the seat.  This releases the seat's connection on the back bar.  Next sort of wiggle the seat until you can push it forward and then separate the seat from the frame. Then to collapse the frame, look for the piece half way down the frame that looks like it can slide. Slide the pieces up (on both sides of the frame) until you can fold the frame in half.  It is still pretty bulky.  I dont think the seat part collapses any further.
Hope it helps.
Jul 11, 2008 | Zooper Boogie Jogger
Quinny Buzz Jogger Logo
242 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
