Question about GE Washing Machines
The control knob on my WBSR1060T5WW top loading washer is not making contact (it is spinning freely.) It will not pull out nor push in. How do i remove it to check the problem? It does not simply pull off like the dryer knobs.
  • 1003 Answers
SOURCE: Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Posted on Feb 02, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 107 Answers
SOURCE: Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Posted on Mar 13, 2009
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
  • 1937 Answers
SOURCE: Kenmore Elite Washer Does Not Spin
This a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20992991
and you'll see a list of major sub-components with diagrams and parts.
The brake on these washers is driven by the clutch on top of the transmission.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If the washer drains the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again or stopping and starting the cycle knob, and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, or stopping and starting the washer torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 16, 2009
Load size dial on washer spins freely instead of moving to setting
That setting has to do with how much water is let into the drum. You can get a new switch for that. If you post the model number.
Nov 18, 2013 | GE Profile WPRE6100G Top Load Washer
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
Jun 04, 2017 | General Electric WHDSR209DWW Top Load...
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Can't get the push-pull washer control knob off
push the knob in then turn counter clockwise it does not push on it screws on
Jul 10, 2009 | Kenmore 88752 Top Load Stacked Washer /...
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
Washing machne problem
The help that you gave me was completely wrong. The support ring was okay. I solved my problem by buying a new timer and control knobs. The teflong 'gears' were worn out so the knobs rotated freely.
Ronald Nelson
Jun 25, 2008 | GE WBSR3140DW Top Load Washer
Kitchenaid top load washer
could be either take out the two screws at the base of the control panel and raise it up after you back the screws out pull the panel forward then lift it up its on hinges check all the connectors next you will see a black plastic piece in the center of the timer pry it loose with a small screw driver till it extends but is not all the way off this will release the control knob make sure the inner ring is on the shaft properly then posh the knob on tight and push the plastic tab back in if that doesn't fix it replace the timer
Feb 13, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
47 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
