I was just playing around with the brand new Philips VOIP841 skype phone, when I decided out of randomness, to punch out the IP address of the phone as it appears in my router's connected users list, in my web browser.
Much to my surprise, apparently the DECT phone itself has a built-in http (web) server! a prompt popped up, asking me for my username and password to access the server named ''voip841''. I could not find any reference to this whatsoever, in my manual.
I was wondering if anyone knew if there were any defaults I could try to access this mysterious server with. I want to take a look past that, see exactly what's inside this wonderous server, and change the password (I really hate defaults).
In the meantime, i'm going to have to do a port scan on that IP, and see what other ports open I should know about.
if you don't have skype application on your phone, download one because the site that want to log you in can not connect,the best thing is to have the application of your phone size either facebook,tweeter or any kind of application
Try retrieve the IP address of your VOIP841, on the handset press the “Menu” button, navigate to the “Settings” menu and choose the option “Network”, then "DHCP", it should give you an IP address, make a note of this. Open your Internet browser and type in the IP Address of the VOIP841
into the address bar. The Internet browser will show the internal
Internet page of your device. Login with the following username and password:
Username: philips
Password: voip841
After logging in please navigate to the “Skype” menu option in the left
side menu. On this page y
ou can type your Skype username and password. Once they are filled in
save your settings and test on the handset if everything is working.
Hi Mudi, This phone only works with Skype. Sorry about that. The phone also handles POTS calls (landlines) but you have to connect a physical phoneline to it! With best regards, Fred
Probably there is typo when entering user name or login. Check and see perhaps there are some unnecessary spaces in user name or password. Also make sure internet connection is on and working + router is configured to accept new connection.
Yes, If your phone supports SIP then you should be able to program any service provider. On the other hand if this is a Skype only phone then you will not be able to use it with any other service besides Skype because they use a non-standard protocol. I tried looking up your phone and the closest I came was : http://www.amazon.com/Philips-VOIP8411B-37-Phone-System/dp/tech-data/B000ND75FW/ref=de_a_smtd
This says in the Tech Specs that it is voip client and softphone compatible (whatever that means). It doesnt say it is SIP compatible. So look up the user manual and if it says that your phone is SIP compatible then you should be able to program any VOIP service provider (90% of them are SIP based) but if all the manual mentions is Skype and nothing else, then you might be out of luck. Hope that helps! -AM
- You need to upgrade to the latest firmware. This is available from the Philips website. Make sure you select exactly the model of your phone. There are some instructions about how to upgrade the firmware in the manual
- Then you need to perform a reset of the system. ie: get a sharp tool and ram it into the tiny little hole on the black box which comes with the phone. If you don't do this after upgrading, it doesn' t work.
- One other tip is to check the firewall settings on your router allow the traffic in/out as well.
I called the Philips service center, and they were a bit useless, but they said if it doesn't work you could try taking the batteries out of the phone for 4 hours. Hmmmm... only try this if the above doesn't work!
DeRegister the handset and then reregister it to the base
On handset
Menu
Settings
Handset
Deregister
Then
1 ) press Reg. Register shall be highlighted. 2 ) press Page key on the base unit until the two indications turn off. If registration is successful,the signal icon displays steadily. If registration failed,repeat the above procedure.
I now feel extremely silly.
