Question about Toshiba 36AF41 36" TV
We havea toshiba bright bomba 29D3DXE tv. There solution has changed and I cant findwhere to resetn it.The picture has zoomed in and about 10% of the picture is lost. If we watching sport where the score is shown in a corner,we cant see it. If a movie has subtitles,they are cut off. I have looked everywhere to change it, but cant find where to reset it.We dont have the manual anymore and no idea how i got it there. Any suggestions?
techman
  • 3130 Answers
SOURCE: Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Posted on Oct 08, 2006
techman
  • 3130 Answers
SOURCE: dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Posted on Mar 20, 2007
SOURCE: toshiba 32a33 32"tv
My dad and I fixed the TV/Video problem over the weekend using one of the solutions suggested. Make sure you stay away from the red wire running from the back of the tube to the circuit board.
1. Take the cover off the back of the TV.
2. On the bottom of the TV is a circuit board that is mounted on top of a plastic tray. Remove the cables running from the speakers by squeezing the tab on the white plug and pulling them up and off the board.
3. Looking at the back of the TV, pull the board+tray out (barely secured in there) and flip it 180 degrees so you're looking at the front of the board.
4. Desolder and remove the TV/Video push button. It's labeled on the PCB, and should be the second button in from the left.
5. Place the tray back in the TV and make sure the other buttons still remaining on the baord are aligned with the buttons on the front of the TV.
6. Put the cover back and you're done.
TV works as good as new again. Of course I can't use the TV/Video button on the TV itself, but the remote handles that fine. 20 minutes max, and no repairman needed.
Posted on Jul 07, 2008
ebrus
  • 30 Answers
SOURCE: Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 28, 2008
  • 700 Answers
SOURCE: Toshiba TV Red Color turns black and regains after a long time
If this is a crt type, it could be a loose connection. Check its RGB board usually located at the backend of the crt tube. Dust, cobweb, carbon built up might be the one causing it.
Posted on Apr 18, 2009
I have a toshiba dlp, replaced the ballast and the lamp. Now the problem is when i put the tv on it takes a while before i get a picture, It starts off very dark then will lighten up gradually. What can be...
It is normal for your TV to take a few moments to reach a brightness level that you can enjoy. A typical Mercury vapor lamp will take amout 2 minutes before it reaches it's optimal brightness. It will continue to increase slightly about 10 minutes longer, but you will not see those subtle changes. So, your TV is functioning as it should, just enjoy the show. If you want to learn a little more about the Mercury Vapor lamp it your TV, please check out my Tips & Tricks. I hope this was of some assistance.
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
Toshiba Bomba 29" TV hot blows everytime I change one. Pls help
Ask you all have to pay why should I , I am an engineer so what' I trouble shoot myself now it's perfectly like new. Why should I tell you how I solve it, you advertise free but wanted to know, OMG premium this and that. Funny .
Dec 28, 2009 | Toshiba 28N33 28" TV
Bright green picture
defective green picture tube crt. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
Picture stretched on samsung ws32z409t tv
Sometimes on a remote theirs a zoom button or HD zoom if you pressed that the tv will do what you describe if you press it again it will go back to normal view.
Jul 27, 2009 | Samsung WS32Z308P 32" TV
Apr 12, 2009 | Toshiba 36AF41 36" TV
Brightness on my tv quit workin
open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
Nov 16, 2008 | Toshiba 36A42 36" TV
Toshiba 36a42 picture problem
try to reset as below,
turn off the TV, remove the power supply from the main socket.
leave it for about 20 minutes
Turn it on again...
Jun 05, 2008 | Toshiba 27AF42 27" TV
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Brightness
as you said your tv is about 3 years old. we cant tell that the picture tube is defective and im sure your CRT socket is in solid contact at that 3 years old tv. for me it could be a path ways to the CRT wirings. a blurry picture may cause a insufficient voltage or a lost of voltage ratings. try to check if you can see and test a leaky capacitor 16V 1000mf near from the CRT wirings ending in contact to the main board. if you cant fix this problem contact a pro to solve your problem. good luck
Aug 24, 2007 | Toshiba 32A43 32" TV
Toshiba 36AF41 36" TV Logo
202 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
