Question about Dishwashers
Whirlpool disher whirlpool dishwasher clean light blinking all the time cannot start whirlpool dishwasher
Run diagnostic by pressing Normal, heated dry, normal, heated dry, normal heated dry. a total of 3 times in 15 seconds.
The dishwasher will reboot and run a test load.
Posted on May 15, 2012
Same as above
Posted on Apr 06, 2010
    Novelist:
  • 111 Answers
Whirlpool Corp. manufactures and sells dishwasherswhirlpool disher - mag-glass_10x10.gif and other home appliances under its own name, as well as under the brands Kenmore, Maytag and KitchenAid. Whirlpool has been in business for more than 100 years. Whirlpool dishwashers carry full warranties for one year, and limited warranties for longer periods on some of the parts.
Not all issues with Whirlpool dishwashers require a service call from a dishwasher repairperson. You can solve some of these with the troubleshooting tips given below. Some dishwashing problems, however, cannot be solved yourself, but require a qualified plumber.
    Has Your Whirlpool Dishwasher Been Recalled?
  1. In 1996, about 500,000 Whirlpool and Kenmore dishwashers were recalled because the wiring within the door latch could potentially overheat and catch fire. The dishwashers in question were sold between June 1991 and October 1992. Affected Whirlpool brand dishwashers have model numbers beginning with DU8, DP8, DU9 and GDP, such as DU8700XY-1. Affected Kenmore dishwashers have model numbers beginning with 665, such as 665.1665591. In addition to model numbers, both Whirlpool and Kenmore have serial numbers ranging from FA2400000 through FA5299999 or from FB0100000 through FB1899999. If your dishwasher is affected by this recall, do not use it or try to repair it yourself. Contact Whirlpool at 800-874-9481 or Sears at 800-927-1625.
    About 162,000 Whirlpool and Kenmore under-the-counter plastic tall tub dishwashers made by Whirlpool and sold between June 2004 and January 2005 were recalled because of an overheating problem in the wash motor. To find out if your dishwasher is affected, call Whirlpool at 866-769-7260. In the meantime, do not use it or try to fix it.
    If your dishwasher is not included in the recalls, you might be able to repair it yourself.
  2. Troubleshooting Whirlpool Dishwasher Problems
  3. If the dishwasher does not fill, check to see that the overflow protection float is unobstructed and can move freely. Press down on it to release it.
    If your dishes are filmy or spotty after they've been washed or you see that the detergent is not completely dissolved, the water temperature might be too low. First, check to see that the dishwasher is connected to the hot water supply. Although the dishwasher heats water automatically at certain times, it will not heat cold water enough throughout the cycle to work properly. Whirlpool recommends that water be 120 degrees Fahrenheit coming into the dishwasher.
    If you're sure the incoming water is hot enough and you're using the correct amount of detergent, but you still have problems with spots on dishes or a dishwasher that won't fill, insufficient water pressure might be to blame. Water pressure must be 20 to 120 per square inch for proper functioning of a dishwasher.
    If the dishwasher isn't draining well, you might need a drain air gap. This is an external part that keeps drain water from backing up into the dishwasher. Plumbing codes in some jurisdictions require the installation of a drain air gap.
    To avoid dishes getting chipped in the dishwasher, make sure you load the dishwasher in a way that the dishes and glassware stay stable in the rack. Do not put delicate china or anything not known to be dishwasher-safe into the dishwasher.
    If you see brown stains on dishes and on the inside of the dishwasher, it is probably because your water is high in iron. The remedy for this is rewashing the dishes, the first time without detergent. Put one to three teaspoons of citric acid crystals into the detergent compartment and run a full wash cycle. Next, run a normal dishwashing cycle with detergent.
  4. Replacing Dishwasher Parts
  5. If the solutions above do not work for you, it is possible that you need to replace one or more dishwasher parts. Whirlpool recommends that you use only factory-specified parts to ensure correct operation and fit. Make note of your model and serial number and call the Whirlpool Customer Interaction Center at 800-253-1301.
Posted on Nov 15, 2009
How do I clean filter for whirlpool disher model number du890dwgq1
It will be in the bottom of the dishwasher Usually unscrews.
Oct 02, 2014 | Whirlpool Dishwashers
Tip
I had blinking "clean light" on my Whirlpool KUDUO3FTSS1 for the whole last...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Dec 19, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 | Dishwashers
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Looking for reset code for whirlpool disher model #665.170.32401
If you have a flashing clean light then you can find the code and reasons why it is flashing at the link below, if something else is going on send a reply with details on what is happening.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 11, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool quiet partner 1 # DU1055XTSQ2
Read this article, it should address your problem.
http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
http://tclaundryrepair.com/
Feb 24, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
2,098 people viewed this question
Top Dishwashers Experts
Owen Barnes
