Question about Pioneer DCS-303 System
Green icon appears on lcd display of the unit(looks like analog clock),cant turn it on and off. but i suspect it is due to overheating? whats the problem of my home theater?
Hey NorthWind,
Mines is doing the exact same... Not due to overheating tho as I haven't used mine in a while and was working fine last time round.
Have you found a solution to your problem yet?
Posted on Feb 24, 2008
I cant find the manual so I dont remember how to set the weekday alarm. Also can you show a picture of what the display should look like when the alarm is set? Or describe it? Thank you.
Press the Alarm button. The weekday alarm symbol will appear. Then press and hold the Alarm button for 2 seconds to enter the set mode (the hour will blink). Use the up/down buttons to choose the hour for the alarm (note the A.M./P.M. if in 12 hour mode). Press Alarm again and the minute will blink. Again use the up/down arrows to set the desired time. Press Alarm once more to exit the set mode.
To activate or deactivate the alarm, press the Alarm button until the weekday alarm icon appears. Then use the up/down arrows to activate or deactivate the alarm. When the alarm is set and active, the time will show. If the alarm has been deactivated, then dashes will appear instead of the time.
The single alarm is set and checked similarly.
I hope this helps.
(I suspect that the weekday alarm icon continues to display when the alarm is active.)
Aug 25, 2010 | SkyScan 31983 Clock Radio
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
There is an icon that came up and it looks like the old fashioned film you would put in cameras. Looks like 2 circles with a line underneath. Ever since this popped up when my flip phone is closed the time...
that could be the indicator for "you have voicemail messages waiting" -- It looks like a little tape cassette. Pick up your voicemail and it will go away.
as for the time display on the front screen, check that you have the screen saver enabled - Settings, Mini Display, Screen Saver, Digital Clock (or analog clock if you prefer), then check again to make sure it is set to On.
Jun 09, 2010 | Nokia 6085 Cellular Phone
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
I have a 'relaxed nature sounds lcd clock' with no instructions
Moderately difficult, but not impossible. ;) I picked up this clock @ second hand store with no instructions and was able to figure it out how to set it in about 15 minutes. I liked the calendar feature on the face and the LCD (as opposed to LED because I prefer my bedroom dark when I sleep).
When setting this clock, one of the keys is to pay attention to the the icons displayed on the face toward the lower left. Default "MODE" is time set. To set the time: Press "SET" followed by either "HOUR" or "MIN" while the display is flashing to increment the hours and the minutes to the correct time. As previously state, the default "MODE" is time set.
Pressing "MODE" one time accesses a secondary clock that you might use if you regularly travel to another time zone (new icon w/ 2 clocks appears). Setting the secondary clock uses the same method above.
Pressing "MODE" a second time accesses the first alarm setting (alarm clock icon starts flashing). Same method to set.
Pressing "MODE" a third time accesses the secondary alarm setting (second alarm clock icon appears and begins flashing). Same method to set.
Pressing "MODE" a fourth time accesses a timer (hourglass icon appears). Same method to set.
Pressing "MODE" a fifth time allows you to set the calendar (calendar year appears where the digital clock display was). Press "SET" to change the date: "HOUR" increments the month; "MIN" increments the day; "MODE" increments the year. Press "SET" again to exit.
Pressing "MODE" a sixth time returns to the default time set mode.
I hope this helps someone! God's blessings in Jesus Christ! ~Thomas
Mar 09, 2009 | Audio Players & Recorders
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Pioneer DCS-303 System Logo
153 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
