Question about Canon imageCLASS MF7480 Laser Printer
Changed ink and now will not print (ip5400) - Canon imageCLASS MF7480 Laser Printer
    President:
  • 995 Answers
Did you properly or surely remove the sealer on the cartridge? If you did it, then you should try the following below:
1) Take the cartridge off and put it back, make sure is in the right way.
2) Push the cleaner bar all the way were it belongs.
3) Press the "on" button for 10 seconds.
4) Disconnect the printer and have re-start.
5) Call a friend that knows about electronics.
Run the printer cleaning utility 3 times in a row (with the cartridges in the printer). if it doesn't work, remove the cartridges and run under hot water for three seconds and then try to blot.
Posted on Nov 15, 2009
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
My color ink was low so I changed the ink but when I print it shows low ink on color and from certain programs(word) it prints fine in color and from other programs(windows photo viewer) it comes out very...
have you changed the print quality? some programs have different print quality settings if you change it to a universal setting like automatic it should be the same. also some programs print lighter to save on ink!
Jul 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Wont print black because it doesnt have color ink
So for now, you can change the print settings to only print in black.
Change the print properties/ colour to grayscale.
May 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Sep 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon imageCLASS MF7480 Laser Printer Logo
old marine
old marine
