Question about Acer Computers & Internet
Acer travelmate 4234wlmi screen problem
Hi, my acer travelmate 4234WLMi screen sometimes shows only colourful lines filling all the screen. I tried to connect it to external monitor and the display on the external monitor is fine.
It comes all of the sudden and for no apparent reason, it can come back normal again. Anyone now what may cause this problem?
Thanks.
Benimur
  • 6966 Answers
SOURCE: Acer Travelmate 6291 LCD monitor problem
Your concern is a typical problem with LCD displays/monitors. There could possibly be three (3) reasons why it is behaving as you have posted.
1. Backlight/Inverter problem;
2. LCD panel problem;
3. Video card problem.
You can do initial diagnosis by:
a. connect the laptop to an external monitor. Using the Fn + F? keys, activate the external monitor to be the default display. If it works, you have eliminated the possibility of the video card having a problem. If it likewise did not display anything or blanks out after sometime, then you have just confirmed that it is the video card that is a problem.
If you have ruled out the video card (using above procedure), you can proceed determining if it is an LCD panel problem or backlight/inverter problem.
To determine if it is a backlight/inverter problem, run the laptop normally even without a display. Let it boot and run through its startup sequence even if you can not see anything. Using a flashlight, shine a light obliquely to the face of the LCD display. if you can see some semblance of your desktop albeit dark, then you have just confirmed that it is the backlight/inverter. If even with the aid of a flashlight, the display s completely blank, then it is possible that the LCD display panel is defective. In some cases it is the flexible flat cable that is at fault.
With any of the aforementioned possible problems, opening the unit is required. This would need familiarity with electronic components and circuitry, use of a DVM and perhaps even a soldering iron. Should you not be comfortable doing this, it would probably be to your best advantage to seek the services of a qualifiedly professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
IB4G2008
  • 3587 Answers
SOURCE: Pink/Green Background Acer Travelmate 2410
you are having an lcd experience of the 3rd kind..i'd venture to say your in for a replacement event.
Posted on Feb 27, 2008
LaptopExpert
  • 458 Answers
SOURCE: Acer Aspire 9303WSMi - 17" LCD Screen is showing coloured static..
More like the LCD Inverter Board..a loose connection would not cause that, unless you pulled the video cable by openening and closing the lid, but again that too is highly unlikely..
Posted on Jun 03, 2008
  • 16 Answers
SOURCE: ''acer aspire one external monitor output splits exter
XP - Simply on a blank part of the screen right click mouse and select properties, you should be in display properties, selections are there and you should get hte picture(s) you want
Posted on Apr 20, 2009
romsky79
  • 822 Answers
SOURCE: Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
Posted on May 20, 2009
Acer TravelMate 2480 Screen sometimes freezes
has your computer bin dropped before because it might be some lose wires or a piece broken somewhere in the computer  if a part inside the screen is broken you will have to buy a new screen all together
Jan 22, 2010 | Acer TravelMate 2480 PC Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
Acer Travelmate 4p20 Display problem
Try to reset LCD video connector, if you have already changed and tried inverter, then check lamp.
Best of luck.
Regards;
Hassan
Sep 03, 2009 | Acer TravelMate 4220AWLMi Notebook
My laptop is only using 75% of the screen space
Check your screen resolution. Since you've updated to the latest driver, make sure the resolution is set to the highest it can go. Also, make sure it is showing an LCD display that cooresponds to what you have.
Dec 30, 2008 | Acer TravelMate 4230-6499 Notebook
My acer travelmate has coloured lines all over
I suggest you post your problem on the following forum. It appears they have active participants and they'd be more apt to have heard or had this problem before.
http://forum.notebookreview.com/forumdisplay.php?f=22
Sep 25, 2008 | Acer TravelMate 290 Notebook
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Acer travelmate does not work from battery
lcd going bad then and maby the power suply sending the power underpowering it overheating maby also is it getting hot on u clean it out cheak cables on it take it apart pop fornt part up out to cheak cables
Jan 01, 2008 | Acer Ferrari 4000 Notebook
Acer travelmate 4500 screen problem
if u have two memmory stick.try to boot with one..if it not ok try it with other one...
Nov 30, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
