Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer thawing and refreezing
I have a GE side-by-side, about 6 years old. Out of nowhere, it has started thawing (lost a load of food that way!), then freezing again. The first time it thawed, I thought one of the kids had left the door slightly ajar. Cleaned it all out, planned on calling a repairman the next day, and the next morning it was fine. This has happened a couple of times in the past 2-3 days.Fortunately, I have another freezer. It is Model #GDD25RGMA CC. Thanks for any advice!
  • Nanabanana Jan 12, 2008
    I called the repairman, and it turned out to be the computer. (Didn't even know it HAD a computer!) Anyway, it is working fine now. It wasn't cheap, of course...but cost less than a new fridge!Thanks for trying!
    Sergeant:
  • 288 Answers
The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
Posted on Jan 09, 2008
The water in the water line freezes up and we have to use a hair dryer to thaw it out. The unit is 7 years old and this is a new continuos problem. Have turned up the temperature as well as adjusting items...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 01, 2011 | GE GSS25SGMBS Side by Side Refrigerator
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water line freeze
It seems to me like 2004 was a bad year for this GE refrig. and for me as well.....I bought one and I'm having the same problem....I have an extended warrenty and if they can't fix it I will demand a new box.....What I would like to know is why did it take four years to start to freez.....Nothing has changed in that time spand just the box freezing in the water line....Good luck all....the sqeeky wheel gets the grease....so ***** like hell.....and don't take no for an answer....
RC
Feb 07, 2008 | GE GSH25JFR Side by Side Refrigerator
Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Jul 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
750 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
