Question about Kenmore Ovens
Can't get my Kenmore Oven to Stop flashing/beeping F1 after using the self clean. We turn off the braker now, but now my oven is stuck on broil and I cant get it to stop Fl/BP F2. How can I fix this?
  • 126 Answers
Probably not. If this is a frigidaire made unit, you will probably have to replace the clock/oven control. That will set you back around $130.
Posted on Nov 15, 2009
The digital controls on my frigidaire stove do not work. It beeps continually and it flashes F1 on the screen. The oven doesn't work but the burners do. I've tried what it says in the manual to...
F-1 is a sub-code for a few different issues. A button could be stuck, oven cavity getting too hot, or the control has a memory failure. Any of those three failures would require a new control. But first, what happened to the range when it first failed? If you unplug it and try again, what happens?
Aug 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore self cleaning oven The code f1 is flashing and wont stop beeping.....help!
unplug the unit this is due to a bad control this was also previously answered by another tech on this link click here http://www.fixya.com/support/t7527145-oven_giving_f1_error_code if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Apr 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have an old Whirlpool Self-Cleaning oven. I've followed the use guide instructions but still can't get the cleaning light to come on. I have both knobs to clean but the oven light comes on and the...
Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
Jan 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire oven
Try resetting the timer to manual, consult your user instruction book.
Dec 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Ovens Logo
150 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
