Question about Acer Aspire T690 (AST690UP820A) PC Desktop
I just bought an ACER ASPIRE 5532 SERIES LAPTOP YESTERDAY, THE TOUCH PAD WORKED AT FIRST BUT NOW IT DOESN'T?
Press the button to the left of the power button and it should work again.
Posted on Dec 26, 2009
    President:
  • 995 Answers
You might had pushed a keypad shortcut that disabled it. Try going to settings and mouse/keyboard in the control panel and there you should find a solution to your problem.
Posted on Nov 15, 2009
  • Acer Master
  • 13,433 Answers
If you plugged in a external mouse the touchpad may have been turned off, some of these laptops have a button next to the touchpad that turns it off and on. most of the laptops have a touchpad or a finger or a mouse icon on one of the F1 to F12 keys
to turn off / turn on the touchpad in such laptops you would hold down the FN button and then press the appropriate F key.
also if you have a external mouse connected, try disconnecting it first.
Touch pad not scrolling
Go to Control Panel and check it about the drivers.. if there is change the options.. otherwise install the touch pad drivers...
Mar 31, 2014 | Apevia iTEKIRO Replacement Laptop AC Power...
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Once a mouse was attached the Acer Aspire 5532 touch-pad no longer works. When the mouse is disconnected the touch-pad still will not work. I do not see a toggle button to use to toggle between the mouse...
HI Diane,
Since you haven't provided the Windows Operating System version (XP/Vista/7 or other?), I'll have to provide the general scope of what you should try.
1. Go to the Control Panel and open up your Mouse section
2. Look through the different tabs until you find an option to either "Enable" your touchpad, or one that says the equivalent of "Disable Touchpad when external mouse or device is connected"
The idea is to accomplish your aim by working with the mouse settings provided for your system. Good luck and go easy on the "blue thumb". Please provide more specific information before a negative response.
Thanks
Aug 29, 2010 | Acer Aspire 4520-5582 Notebook
Unable to use touch pad....rt clk and slide key
If the laptop is that new, the problem is probably the touch pad "disable" button. Look for a small button just above or near the touch pad and make sure the touch pad is not turned off. If you cannot find the disable button, look in your user manual for the touch pad disable.
Jun 01, 2010 | Acer Aspire 5100-5022 Notebook
Mouse quit working on my Lap Top it is a Aspire
First of all check whether the touch pad is lock (Fn+F7(?)). If you use an external mouse/ usb mouse, check usb cable connection, as long as you didn't drop it on the floor it should be ok. If the built in touch pad doesn't work, could be caused by ribbon cable connectivity that has dirt or moist. To fix it need to open the upper case
Apr 08, 2010 | Computers & Internet
How do i turn off the touchpad on my acer aspire 5532
HI,
Please find the steps to disable the touch pad for your laptop.
Follow the steps below to access device manager and disable touch pad.
  1. Click on Start.
  2. In the Start Search Box type devmgmt.msc and press enter.
  3. Expand Mice and pointing device.
  4. Right click on Touch pad and Disable it.
  5. Restart the computer and verify if it works fine.
let us know if you were looking for something else.
Jan 20, 2010 | Acer Aspire AS5520-5537 Notebook
Samsung x20 suddenly started humming.
Hi The touch pad might be disabled this happened to mine not to long ago. There is a button right next to the power button with a picture of a finger pointing press that and the touch pad is now enabled. Fn+F7 sometimes work on different models on Acer aspire 5532 doesn't work
Jan 16, 2010 | IBM ThinkPad X20 2662 Notebook
Does the acer 5532 have a touch pad and also a
The generic specs for the 5532-5534 series is listing that it has both a touchpad and a Crystal Eye Webcam, however there is a special note remarking that there is a chance the device will not have a webcam depending on the specific model within the series. Acer model numbers are generally, 2 letters followed by 8 digits followed again by 4 letters, so a full model number would look like: AS55325421WLMi
If you happen to have the full model number I can let you know for sure.
Thanks!
Dec 09, 2009 | Cameras
How do i use my webcam on acer 5532
You don't have a web-cam on your Acer Aspire 5532. Sorry, I actually bought a brand new Acer Aspire 5532 with Windows 7. It's really nice but that little black circle at the top of your screen is not a camera. I do believe you can have one installed though.
Good luck,
Brandonmxb
Dec 08, 2009 | Acer Aspire 3610 Notebook
Acer Aspire  T690 (AST690UP820A) PC Desktop Logo
1,449 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
