1993 Zenith AVI 36" TV
When I turn on the tv, the screen goes green (with some horizontal lines) for a few seconds ( very quickly) and then the green merges to the center into vertical line and the screen then goes blank. Meanwhile all other functions are fine, sound, tuner, etc.
Is this something that could be repaired or this set destined for the electronic recovery yard?
  • 233 Answers
Most likely the fly-back transformer is failing, you can take it in and get an estimate to decide if it's worth the cost of the part and labor.
but my guess is that you may be better off getting a new TV
Hope this helps
thanks for the rating
Posted on Jan 09, 2008
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
Mar 23, 2009 | Sony KP-46V35 TV
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Picture reduced to a horizontal line across center
sounds like the vertical, more info
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Dec 09, 2006 | Mitsubishi CS-31305 TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
