Question about Acer Aspire M1641-U1521A PC Desktop
No signal appears everytime I turn my PC ON. Blank screen appears. I checked my RAM module and its OK. Seems like theres a problem on the VGA port.
    Problem Solver:
  • 19 Answers
There is one of 2 problems here. first check the video card, since you mentioned port this sounds like its an on board video, so get a generic pci video card...nothing fancy just checking for video, if your out of pci slots either 1 remove one to test video or if your motherboard supports agp then get an agp video card. there like 20 bucks just go to a local repair shop. if that doesnt solve the problem then its the monitor.
Posted on Nov 15, 2009
Acer aspire ax1700-u3700a. The dvi port has stopped sending signals to the monitor but the vga port works. I use the vga port but the computer sometimes gives blue screens then strats back woring normally....
I can see you do have two issues here.Let us first fix the DVi port.Please see follow the steps below.
1. Please check video configuration by looking it up on the PC control panel.
2. Please make sure you choose the both DVi and VGA port by simply placing "tick" on the box.
On your second issue.Please follow the steps below
1. The "blue screen" normally comes up if you a faulty VGA cable or the connection is somehow loose.Please check if it is properly plug-in.
2. If the problem continues,I would suggest please contact the manufacturer or the store where the
item was purchase
Sep 04, 2011 | Acer Aspire AX1700-U3793A PC Desktop
My Acer M5640 desktop lately when start up, after the beep nothing appear on the screen, hv to turn off the power and try again, somtimes it will be ok, what's the problem?
As the computer gives the beep it shows it is working, it has pass the Power On Self Test.
Your problem is a loose connection, either at the Graphics card slot or on the monitor VGA ports.
Check the VGA ports at both the Graphics card and at the monitor. Also clean the RAM modules of dust and reinstall.
Take care!
damnor01
Apr 17, 2011 | Acer Aspire m5640 PC Desktop
Hp dv 2500 blank screen ..system will not start
There are many promblems that can associate to a blank screen, 1) test you laptop using the external source such as HDMI, VGA, SVIDEO port to a monitor or Tv to see if you get a display. ( make sure your tv is tunned to the correct signal) If you get something to you tv, monitor via the enteral ports, then your screen inverter is bad, or loose connection in the wiring system between your screen and your laptop base. If that doesn't work then 2) Its a ram memory error issue, take out your back service panel and remove the rams, and rotate rams if two of the memory bank are used. Rotate vise versa with each ram to see if it works. If it works, one of your memory module is bad. If not 3) you motherboard or cpu is bad, Most likely the motherboard, Hp computer of your model does tend to overheat, and destroy the vga chipset or fry the compacitors, if this is the case, your laptop is pretty much history, unless you replace the motherboard itself.
Jan 30, 2011 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
Blank display, machine seems to boot ok but display is blank.
If you hear your computer beep once then your system has no problem. If it does'nt show a display, try to check the power of your monitor, if it has power. Check the power cords and also the vga connection.
Nov 10, 2009 | HP Pavilion dv9000 Motherboard
My monitor wont come on it says it has no signal i turn onpc but monitor is blank
First open cpu cabinet then REFIX RAM memory.
Pull cmos cell for 10 minutes then all settings are defaults.
Then reconnect vga cable from your monitor to cpu vga port.
Then when you power up press continue F8 key so you can see safe mode and other menu then enter in enable vga mode then go to control panel then dispaly property then settings then change screen resolution to 1024*768 then apply and ok.
Then restart and check .
Aug 18, 2009 | Gateway 507GR PC Desktop
HP d330 fried during pwr serge, fixed, boots but no screen signal
there are several possibilities. 1. replace the ram, make sure that its a good working ram module. 2. review all your work from system board to power supply. 3. try running it temporarily without the cmos battery. 4. check your monitor. 5. check your VGA. 6. retry and retry.
Jul 13, 2009 | HP Compaq Business Desktop dc5800
No graphics on the screen
press F8 key while turning on the laptop it will give you the advanced boot option select safe mode from the menu.It will take you to the safe mode , then do a system restore to the previous date when it was working fine
Jun 25, 2009 | HP Compaq nx6110 PC Laptop
Can't get monitor to connect
There are a few things to look at. It is very obvious that the screen is in good condition since you can see the message on it. Now the problem lies with either the RAM and/or the VGA. If you are using an onboard VGA, try a PCI VGA card. Try to resit the RAM modules also. If you have more than one mem chip, then do it one after another. It might be one them is fault and hence blocks the signal to video. Finally, any newly installed card should be temporarily removed ok. With these, I am sure the problem will be over. Good luck
May 27, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
3M MP8725B Projector
apply any video signal from video in(yellow jack and yellow socket)if it is ok-change your vga cable-and confirm that input in pc mode.if no signal appear from video in also you must contact a good service center.
Jul 04, 2008 | 3M Office Equipment & Supplies
Acer Aspire M1641-U1521A  PC Desktop Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
