Question about Bosch Dishwashers
The dishwasher is trying to pump water even though the door is open,its making a gurrgling sound.
  • Bosch Master
  • 19,396 Answers
Hi.
That means that either there is a contact in door lock wiring, or that the timer control board has blown.
Call support at the number listed on the owner manual to get a quote on repair.
Regards.
Posted on Nov 15, 2009
Motor runs with door open. No water in pan.
Sounds to me like there may be water in the moisture sensor. Your dishwasher is probably leaking and the noise you hear is the drain pump activated.
Apr 02, 2015 | Bosch SHV46C03 Built-in Dishwasher
My model number is 70209974. My dishwasher either won't start at all or it starts sounds as though it is filling then stops and make a humming sound but nothing is happening. There is no error code...
Hello
Unplug the appliance and take off the inspection panel below the door.
Check to see if the base has water in it.
When these machines have a leak into the base the circulation pump motor tends to sit in the water (poor design).
If your motor was wet, this would trip the mains.
It may also blow the pcb.
You could be looking at a pcb and motor change to repair your appliance.
It may be worthwhile drying out the motor, a fan heater aimed into the inspection panel (open) would help.
Once dry, try the machine again.
If still no joy, take the door apart and see if there is physical damage to the control board in the door.
Aug 22, 2011 | Belling 24 in. IDW603 Built-in Dishwasher
Dishwasher runs part way thru cycle then f2 cumes up all lights come on and draim pumps runs all the time even with door open
F2 signifies high water level. Check the drain pump and drain hose, make sure they are not clogged. Check the operation of the water inlet valve.
Feb 23, 2011 | Asko D1776 Built-in Dishwasher
My dishwasher no longer cleans my dishes and white spots remain even when jet dry is being used.
Dishwashers rely upon water circulation. Make sure there is nothing blocking the pump receiver at the bottom of the washer, like paper labels from gars, or large food pieces. It also relies upon the proper amount of water in the washer. After the washer fills and starts its cycle, squeeze the handle to open the door but do not open the door until all the sound has stopped. The water level should be visible and close to the top edge of the basin. Don't worry, opening the door after the pump has stopped will not spill water on the floor. If the water level is good and you are sure there is nothing blocking the pump receiver, check the stem in the center of the basket.
Sep 20, 2010 | Dishwashers
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Mar 29, 2010 | Bosch Dishwashers
My Bosch dishwasher, S9J1F will not clean things properly, I've changed the arms, cleaned it. I think the arms don't seem to spin properly, (I bypassed the door switch so I could see them spin)I have tried...
not enuff water in it or pump blockage or bad pump impeller. if you ran it with the door open even if the arms didn't turn you should have got drenched is the bottom covered with water about 1 inch deep some times the fill valve screens get clogged and don't let in enuff water if plenty of water in it look for somthing in the pump
Dec 08, 2009 | Bosch Dishwashers
Pump will not shut off even with door open
Hi, There is a float under the dishwasher to protect from flooding... If there is a leak and there is water under the dishwasher in the pan then the float switch will turn on the drain pump...
first I could remove the toe panel check in the pan for water... if no water still check the float it maybe stuck up (soap can get under the float and hold it up)
remove water and make sure float in down... if not you may need a new float switch...
Sep 28, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Dishwasher not empytying
call a pro before you possibly cause damage to unit. the clanging you hear is probably something giving way when the drain pump kicks in and cannot turn. if your mechanicly adept and somewhat adventerous you may try to disassemble the pump and clear it yourself , but i advise against it.
Apr 06, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
