How do you remove a 09 plate merc b class door handle i have removed the torq screw from the hole in the inside of the door which would normally release the lock section of the handle but it still seems too tight.i think there may be another screw somewhere else.can you help
  • 132 Answers
ON THE BACK SIDE OF THE HANDLE THERE SHOULD BE TWO BOLTS THAT YOU NEED TO REMOVE
Posted on Nov 15, 2009
Remove the osr door lock on a mercedes c200 class (w204).
You have the loom connection and a bar down from the door handle which has a plastic clip on it ,been a while since i done a merc one ,done a new focus last week ---- what a job unlike the older models it was rivited to the window channel and i had to remove the whole lot ,big screwdriver and broke the plastic clips so i could get the whole unit out ,bit of two pack epoxy adhesive to repair the plastic and out it went again ,
Feb 10, 2015 | Mercedes-Benz C-Class Cars & Trucks
How to remove carburetor from 235 husqvarna chain saw
Start by removing the 3 anti vib spring screws, one on the front underside of the saw, one at the rear underside of the saw, and one at the r/h side of the cylinder, remove the 3 screws holding the l/h side of the rear handle and remove the plastic trigger and throttle lock, the handle and spine will now come away as an assembly from the rest of the saw, now remove the screw at the top r/h side of the saw and remove the square orange plastic plate, once removed you will gain acess to the two 8mm nuts under the air filter securing the carb, there is also one torq screw to remove before the carb and filter bacl plate can be removed, you will also have to pull some of the fuel hoses from the carb to completly remove it.
Dec 23, 2012 | Garden
Exterior door handle on 97 thunderbird
You will have to remove the door panel. To do this use a phillips screwdriver and remove the two screws under the inside door handle. Then lift and remove the section. Remove another screw from the interior lower left corner. Pry the window crank apart "if exists" then use a T20 torq bit to remove the screw in handle. Remove the panel by lifting and pulling at same time. With window in up position you can see inside the hole a rod going from the door handle to a bracket with a Yellow clip. Slide the clip to the open position and pull the rod out of the clip. From the outside of door under the handle there are two rivets. Use a punch and knock out the center of each rivet. Then use a 1/4" drill bit and drill out the rivet. A flat tip screwdriver will be used to knock off the rest of the rivet. You will need two flat head screws and lock nuts or to reinstall the handle. Lift out old handle with attached rod. Twist rod as you pull to remove it and install it into the new handle. Place the rod through the hole and look inside to be sure is will move to the location of the yellow clip.Install the screws from the outside and the nuts from the inside and tighten. From inside connect the rod to the yellow clip. Lift on the rod while closing the clip. Then test door handle. If it doesn't work properly the rod was not lifted or pulled outward enough. Redo that step until you get it right. Reinstall inner panel as removed.
Feb 26, 2012 | 1997 Ford Thunderbird LX
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
How do you remove the inside door panel backseat right side of a mercury grand marque 1996
Door Panels REMOVAL & INSTALLATION 1989–91 Vehicles
  1. Disconnect the negative battery cable.
  2. On 1990–91 vehicles, remove the speaker grille.
  3. Remove the retaining screws from the door inside handle cup.
  4. If equipped with armrest courtesy lamps, remove the lens, detach the bulb and wiring assembly from the pull cup and remove the pull cup.
  5. Working through the pull cup opening, disconnect the remote lock rod from the lock knob.
  6. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate, if equipped.
  7. Raise the plate to expose the window switch and power door lock switch and disconnect the switches.
  8. Remove the retaining screws from the armrest finish panel.
  9. Remove the retaining screws from the armrest and remove the armrest.
  10. Using a suitable trim pad removal tool, carefully pry the trim panel plastic push pin retainers from the door inner panel. NOTE: Do not use the trim panel to pry the clips from the door inner panel. Replace any bent, damaged or missing push pins.
  11. Disconnect the radio speaker wiring, if equipped.
  12. Remove the trim panel and watershield. To install:
  13. If the door panel is to be replaced, transfer the plastic push pins to the new panel. Make sure that the watershield is positioned correctly to the door sheet metal. Remove the door pull handle from the old panel and transfer to the new one.
  14. Position the door panel loosely to the door belt opening and route the wiring harness through the appropriate access holes in the panel.
  15. Connect the radio speaker, if equipped.
  16. Align the plastic push pins on the door panel to the holes in the door sheet metal and press the pins into place.
  17. Install the armrest and route the window regulator, remote mirror cable and power lock harness through the access hole.
  18. Install the armrest finish panel.
  19. Install the power window regulator switch plate housing to the armrest connecting the power window switch, power door lock switch and remote mirror bezel nut, if equipped, prior to securing the retainer screw.
  20. Connect the lock remote rod to the lock knob retainer boss. NOTE: Make sure that the remote rod is fully seated into the retainer boss, then function manually or with the power switch to ensure smooth operation of the lock knob.
  21. Install the bulb and wiring assembly.
  22. Install the lamp lens, if equipped, and the pull cup.
  23. On 1990–91 vehicles, install the speaker grille.
  24. Connect the negative battery cable. Fig. 1: Front door panel — 1990–91 vehicles 84170064.gif
    Fig. 2: Rear door panel — 1989–91 vehicles 84170065.gif
1992–98 Vehicles
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front. Fig. 3: Front door panel — 1992–98 vehicles 84170066.gif
    Fig. 4: Rear door panel — 1992–98 vehicles 84170067.gif
    Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front 89600p08.jpg
  4. Detach all connectors from the switch housing.
  5. Remove the door inside handle cup.
  6. Remove the push pin from the door trim panel upper front extension and remove the screw.
  7. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel. Fig. 6: Detach the switch housing electrical connector and remove the housing 89600p09.jpg
    Fig. 7: Remove the door inside handle cup 89600p01.jpg
    Fig. 8: Remove the screws from the door panel in the front and on the upper extension 89600p02.jpg
  8. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  9. Lift the door panel upward and snap out the panel. Fig. 9: There are also retaining screws located in the map pocket as well as . . . 89600p03.jpg
    Fig. 10: . . . along the bottom edge of the door panel 89600p04.jpg
  10. Disconnect the necessary wire harnesses and remove the panel. To install:
  11. Connect the wire harnesses to the door panel, as necessary.
  12. Install the door panel by pushing in and down until it snaps into place.
  13. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  14. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  15. Install the push pin covering screw on the panel upper front extension.
  16. Install the inside door handle cup.
  17. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  18. Connect the negative battery cable. Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door 89600p05.jpg
    Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel 89600p06.jpg
    Fig. 13: Detach the connectors for the trunklid and fuel door release switches 89600p11.jpg
    Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle 89600p17.jpg
Aug 26, 2010 | Mercury Grand Marquis Cars & Trucks
Need to remove door panel. How?
Door Panels - REMOVAL & INSTALLATION
The many different design interiors make it impossible to list each fastener location. The trim panels that must be removed are held in place by screws and clips. These locations vary from model to model. After removal of all the fasteners that you are aware of, if the trim panel is still firmly attached, you probably missed a hidden fastener. If this happens, gently and carefully pry the area looking for the location that doesn't flex. The location that does flex is where you'll find the fastener(s) you missed. Screws and retainers are usually hidden. Handle trim, reflectors, light lenses and other plastic pieces usually cover the main retaining screws. Take great care with the plastic trim panels. Plastic trim panels are usually very hard plastic and extremely easy to crack. The following steps can be used to guide you through the removal and installation of the trim panels, but you may need to alter these steps to your specific needs.
  2. Pull the inside door handle to the open position, unfasten the screw and remove the handle escutcheon.
  3. If equipped with manual locks, remove door inside locking rod knob.
  4. If equipped with manual windows, insert a suitable window regulator handle removal tool behind the handle. Disengage the retainer, then remove the handle.
  5. If equipped with power windows and locks, use a small flat-bladed prytool to carefully pry the switch plate up, then detach the power component electrical connectors.
  6. If equipped, remove the screws inserted through door armrest and pull handle assembly into door inner panel or armrest hanger support bracket.
  7. Lift the seat belt trim panel up and remove the hidden retaining screws.
  8. Remove the outside side view mirror trim plate retaining screw. Lift the panel up to disengage the retaining clip, then remove the trim panel from the door.
  9. On styles with courtesy lamps located in the lower area of the trim panel, disconnect the wiring harness at the lamp assembly.
  10. If equipped, use a suitable tool to pry the reflector plate from the side of the door panel.Remove bottom trim cover retaining screws, then remove the lower trim cover.
  11. Remove any necessary electrical connector CPA clips, then unplug the electrical connectors.
  12. On styles with integral armrests, remove the screws inserted through the pull cup into the armrest hanger support.
  13. Unfasten the door trim panel retaining screws. The locations of the screws will vary depending upon the year of model of vehicle. The screws are usually hidden, so be sure to look carefully to make sure you don't miss any.After all of the trim panel retaining screws are removed, slide a suitable trim panel removal tool between the door panel and door perimeter to carefully disengage all of the trim panel retaining buttons. Make sure to position the tool close to the fastener, or the trim panel may be damaged.
  14. Carefully lift the trim panel away from the door, checking to be sure all of the retaining buttons and screws and electrical connectors are unfastened.
To install:
Before installing the door trim panel, check that all trim retainers are securely installed to the panel and are not damaged. Replace damaged retainers as required.
  1. Connect electrical components where present.
  2. To install the door trim panel, pull door inside handle inward; then position the trim panel to the inner panel, inserting the door handle through the panel hole.
  3. Position the trim panel to the door inner panel so that the trim retainers are aligned with the attaching holes in the panel, and tap the retainers into the holes with a clean rubber mallet. Install all previously removed items.
  4. Install the remaining door panel components in the reverse order of removal.
  5. After installation, connect the negative battery cable, then check for proper attachment and operation of electric components, if so equipped.
Hope helps (remember rated and comment this).
Jun 29, 2010 | 1987 Oldsmobile Delta 88
Where can I read, for free, how to remove the drivers door panel and remove and replace the window regulator. I see these questions on this site but there are NO ANSWERS. What's with that? 1998 Cadillac...
GM Cadillac Deville_Fleetwood_ELD_Seville 1990-1998
FRONT DOOR
Fig. Front door panel-1990-91 Deville and Fleetwood
Fig. Front door panel-1992-98 Deville and Fleetwood
Fig. Carefully pry up the power window switchplate and . . .
Fig. . . . gently remove it from the door panel
Fig. Remove the door pull strap retaining screw covers by gently prying them off
Fig. Remove the door pull strap retaining screws
Fig. Gently pull the inside door handle panel down and . . .
Fig. . . . release the rod from the handle
Fig. Carefully lift up the door panel to release the . . .
Fig. . . . retaining pegs on the door panel
Fig. Do not pull the panel too far away from the door, as some components still have wiring harness connected
Fig. Detach any necessary wiring connectors and remove the door panel from the vehicle
  2. Insert a flat-bladed tool between the door panel and the rear edge of the power window switch plate to disengage the retainer from the panel.
  3. Slide the power window switch plate forward, then label and detach the wiring connectors.
  4. Remove the power door lock switch plate retaining screw. Remove the switch plate and detach the wiring connector.
  5. Remove the pull handle retaining screws.
  6. Using a thin-bladed tool, carefully pry the courtesy lamp lenses off. Remove the courtesy lamp bulb.
  7. Pinch the courtesy lamp retainers and pull out the lamp socket holder. Detach the courtesy lamp wiring connector.
  8. Remove the door panel retaining screws.
  9. Using tool J-2459B or equivalent, disengage the door panel fasteners from the holes in the door. Detach any remaining wiring connectors and remove the door panel.
To install:
  1. Position the door panel close to the door and attach the wiring connectors.
  2. Align the door panel fasteners with the holes in the door. Push in on the door panel to install it to the door.
  3. Install the door panel and pull handle retaining screws.
  4. Install the courtesy lamps and switch plates.
  5. Connect the negative battery cable.
I really hope help you with this (remember rated it) Good luck.
Oct 12, 2009 | 2001 Cadillac DeVille
Broken handle on dishwasher
Bernie,
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Jan 09, 2009 | Maytag Dishwashers
1994 buicklesabre passenger rearview mirror
you will need a pad puller and a 10 mill. socket also a 15 torq bit take the switch plate loose with a nylon bone or a screw driver disconnect all the wires be careful the power mirror switch still has power to it as does the seats. where the inside door handle is take the torq bit and remove the screw then remove the plastic piece there you will have to disconnect the lock if power door locks now go to the rear of door pad and remove the reflector lamp with the nylon bone or a screww driver stick it in at the bottom and push down the reflector will start to come out now use a 10 mill socket to remove the bolt go to where the switch plate is and remove two 10 mill bolts now take the pad puller and start removing the xmas trees around the door pad be careful they are set in cardboad you don't want to rip it. also if it is an older car the inner feather will stick to the door pad that is okay don't try to seperate it you will tear up the door pad. Now disconnect the rest of the wires for the courtesy lights.
Sep 19, 2008 | 1994 Buick LeSabre
Microwave Oven Door Handle Replacement
You shoul take off the hole door, use something like a flat screw driver and wedge the plate off.
some of the mics got tamper holes where it hooks in.
Hope it works...
Sep 09, 2008 | Whirlpool MH7155XM Microwave Oven
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
