Indesit iwme 126 not draining water away
Hi Ive only had my indesit iwme 126 for 2months, and now after the cycle is complete the drum is still full of water, have tried using different programmes but still having the same problem.
COXY
  • 76 Answers
SOURCE: Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Posted on Nov 30, 2007
  • 1294 Answers
SOURCE: indesit washeing machine
Karen, that was nice.........
Posted on May 31, 2008
SOURCE: indesit widl 126-problem with the
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Posted on Sep 15, 2008
  • 135 Answers
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Posted on Nov 15, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
Indestit washing machine model iwme 126 is stuck on 4h does my one know how to restet the machine or fix this?
Try pressing and holding the power button until it flashes then turn off and turn on again the light will flash again and then reset the machine.
Not sure if this will work on this model but has worked on two Indesit machines I have had (both different models)
Apr 18, 2015 | Washing Machines
I have a silver Inesit WIDL 126 S washer dryer. Whenever the wash cycle completes, it then lets in some water from the inlet. Then stops. I tried draining it, it drains, then lets in water from the inlet,...
A device called a solenoid open and closes when activated by the control board (circuit controller). If debris collects inside of the chamber when it is open or closing, it can leak or simply shut down. This device will open upon command and allow water to enter or exit. It takes its orders from the command center and if it is damaged, plugged, or no longer capable of switiching on and off, it needs replacement.
Mar 12, 2014 | Indesit W 123 Front Load Washer
Indesit WLA111 stuck on rinse cycle
There is a drain plug and filter under the drum. You access it from the front by taking the panel under the door off. Get ready for lots of water to come out when you take the drain plug off. Clean out the area of the filter and drain plug.
Feb 10, 2014 | Indesit WA 115 Front Load Washer
I HAVE AN INDESIT WASHING MACHINE,MODEL NO IS; WIB 101 [UK]. THE FAULT WITH THE MACHINE IS THAT IT WILL NOT DRAIN ALL THE WATER AWAY AND WHEN ON SPIN ONLY HUMS AS IF THE MOTOR IS STUCK,BUT ON A WASH...
If there is a filter on the front (behind the kick plate), remove it to clean it out. (lot of towels required as there will be a lot of water to come out if the drum is full).
If no filter then there's likely to be something jamming the pump and that would have to be stripped out to clear it.
May 11, 2011 | Washing Machines
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit widl 126 s washer/dryer wont drain
Ive fixed my problem by turning it on, and after it does the standard pumping part pull out the power plug. Then when you plug it in again it will completely drain and its all reset again.
Aug 28, 2008 | Washing Machines
Hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Mar 25, 2008 | Indesit W 123 Front Load Washer
Indesit DG 6100
the seal on the top drawer is damaged
Oct 05, 2006 | Indesit 24 in. D61 Free-standing...
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
