Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Door will not close, can you buy and replace catch ?
  • Hotpoint Master
  • 3,463 Answers
All the parts are readily available, you probably need to replace the door catch, and door spring.
You need to seprate the 2 door halves to carry out thios repair.
Please rate my solution.
Thnaks.
Posted on Nov 15, 2009
Door will not lock light stays on
Usually this is caused by the door being bent, the hinges being bent, or a worn out door strike/catch not holding the door tightly closed. Lol, got kids?? Mommy's little helpers love to lean on the doors(the ones that open/close vertically). Also, slamming the dryer door can break the little plastic arm attached to the door switch--I see MANY switches with the arms broken in-half or the strikes/catches damaged from slamming. Usually a relatively simple repair to replace the strike/catch.
Aug 13, 2015 | Kenmore Dryers
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Sep 08, 2014 | 2000 Toyota Camry
How do I fix a sticking door catch?
Buy door latch lub for auto parts store.
May 26, 2014 | 2005 Renault Grand Scenic
DEL--repeatedly does not sense door closed to lock and start
the door door catch striker is worn replace it and then try you should be able to buy on line quite cheap
Oct 02, 2012 | LG Washing Machines
W310 door catch wont close
need to remove the rubber around the door its a bit of a faf though
Sep 27, 2012 | Miele W310 Front Load Washer
Genn-Aire JUMV 8208BAB door on microwave will not stay shut
try to adjust the latch, if not you must replace go to www.repairclinic.com and buy it
God bless you
Jul 16, 2012 | Microwave Ovens
The driver side door on my 2002 chevy blazer wont close.how do i fix it?
Door pins are a common failure on that series of Blazer/S10's. Also, another point of contention that the door faces is a sticky latch. Basically, the door latch re-latches itself and when you shut the door into the catch, it slams into it and bounces off. An easy fix is a 3 part cocktail of brake parts cleaner. Open and shut the latch with a screw driver acting as the catch and your interior door handle a few times. P'Blaster, open and shut the door a few times with the screwdriver acting as the catch. Finally, a good shot of white lithium grease. Open and shut the door with a screwdriver as the catch several times. Once you feel it is un-stuck, actually close and open the door several times. If you notice the door rising every time it catches, you MUST replace the door pins (cheap fix). If the door still has issues, replace the door latch (and since you're in there, do some PM and replace the actuator as well).
Apr 08, 2012 | 2002 Chevrolet Blazer
The Driver's side door of our 1996 Saturn Stationwagon won't catch when you close the door. In otherwords, if I drove the car, I can close the door but it doesn't catch and therefore the door...
first make sure the bolts which hold the latch mechanism to the door are firmly screwed in. if that ain't it, remove the post which it clamps onto from the door jamb and switch it with one from a back door. close the back door firmly, lock it and never use it again. if that ain't it go to www.getsaturnparts.com and buy yourself a new door latch mechanism and pay an auto glass shop to put it in for you.
Sep 07, 2011 | Saturn SW2 Cars & Trucks
Altec lansing im7 docking door
I have the same problem. I have a Brabantia bin and the catch is the same as the IM7. You can buy replacement catches from Ebay for the Brabantia Touch Bin. Just need to work out a way of swapping them over
Sep 12, 2008 | Audio Players & Recorders
Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
