Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer says 5100 error orangedlight and no 2 flashing
  • 4,041 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Jun 21, 2010 | Canon Pixma MP480 All-In-One InkJet...
Getting an error 5100 on my i560 printer
error 5100 & flash 2 times, you need o replace code strip or carriage unit or logic board
May 27, 2010 | Canon BubbleJet i560 InkJet Printer
Printer light is flashing.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width) The unit is not homing, check for obstructions.
Mar 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Green and orange light is blinking continuous.. and the cartridge head is not moving. ip1980.. please help..
check the status of the printer in its driver. the error will be shown there. error 5100 is the most common. error 5100 means the carriage is experiencing difficulty in moving itself.
Jan 19, 2010 | Canon PIXMA iP1800 Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Mp150 E2 and service error 5100
wheres the answer? I am having the same problem right now, just bought 2 new ink cartridges and its not that,,,,
Jun 07, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer i560 error 5100
Hi You can Try
This been here long time
Error Code 5100
Solution 1:
Solution 2:
Oct 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
