Question about Lexmark Z1320 InkJet Printer
Light keeps on flashing. It won't print. Lewmark z1320
    Problem Solver:
  • 13 Answers
Which light keeps on flashing.
Posted on Nov 15, 2009
MX310 green light flashing and beeping. Won't turn off or reset
You can restart splooler....
--Right click on my computer
--click on manage (a new window open)
--to the left look for Services and application and double click
--this will drop down the some task.
--click on services
--then to your right look for the print splooler
--right click and click on restart.
Mar 04, 2013 | Canon PIXMA MX310 All-In-One Printer
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
My lexmark z1320 will not switch on right. the light just keeps flashing and my computer not picking up device. it was working 24hrs before and no one has used it since. can you please tell me what the...
The flashing of the lights could mean paper jam, alignment problem, ink level low warning. Try to disconnect the printer from your computer. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the printer cover. Reconnect the printer into your computer. Make sure ink levels are substantial for printing. Try to print again.
May 15, 2011 | Lexmark Z1320 InkJet Printer
Paper light flashing when paper tray is full
Paper got stuck in my HL2030 printer I cleared it but red light keeps flashing and won t let me print.
Feb 17, 2011 | Brother HL-2030 Laser Printer
When printing my doc it prints pinkcolor charechters i wnt black and white printing in my lexmark z1320 series
go to printer properties. select printing option as Grey Scale.
u will get B&W print.
Aug 11, 2010 | Lexmark Z1320 InkJet Printer
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
The power switch keeps flashing it won,t turn off i can.tprint
have you tried holding down the power switch fir a period of time
You cay you can print still, have you read through the manul as this light flashing may indicate a problem with the cartridges etc
Jun 02, 2008 | Office Equipment & Supplies
Lexmark Z1320 InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
