Question about Nokia N70 Cellular Phone
Mdling mlowbat kht bgo btry - Nokia N70 Cellular Phone
Baket pag binubuksan ung PSP . need ko pa buksan ung UMD case para mapunta sa MENU ?
ganito gawin mo.. tangalin mo muna ung UMD bgo m buksan psp tpos pnta k s setting hnpin m un autoplay ng UMD tpos ioff m..
Jul 19, 2011 | Sony PlayStation Portable (PSP) Slim...
Need drivers for Samsung VP-D371i please
Hi bartlett g b
Dec 31, 2010 | Computers & Internet
Amplifier draining btry
No power should be applied.
Dec 04, 2009 | Solid Audio Car Audio & Video
I have a KEF KHT 2005.2 Subwoofer that does not produce sound any more, it makes a slight pop sound when i switch it on and thats it, no further sound. The system is about 5 years old but has not had a lot...
The KEF-Subwoofer range (from the PSW1000 up to PSW 3000?) have some built-in flaws in the electronic design.
I just fixed my PSW2000 working along the repairing instructions from:
http://lug.demon.co.uk/kefrepair/
Works! Costs have been about 35,- Euro for spare parts and some (too many) hours of work. If you are used to electronics and soldering you may make it in 2 hours.
Nov 07, 2009 | KEF Audio KHT 2005.2 System
I have only one low beam headlight working, all other lights and both hi beams work. not the bulb. ckd the socket. i dont have 12v at the socket with the ohm mtr lead set on pos btry or neg btry. lights on...
The most likey place will be the double connecter on the driver side where it feeds the headlight check connections on the low beam and there should be a connection to go to the other side. if the wire is not hot from the driver side going to the passenger side that is your problem. Last item will be the head light switch. But check the wires on the oppiste side also check the ground wire.
Nov 07, 2009 | 2004 Kia Optima
Output picture for KORYO KHT 4000 Home THeatre
I want remote of koryo kht 4000 hometheatre
May 15, 2009 | Audio Players & Recorders
DOOR ADJAR LIGHT STAYS ON
This could the problem with one door switch is defective in the car , you need to replace the switch...
Good luck...
Feb 02, 2009 | 1999 Mercury Grand Marquis
Kef subwoofer kht 2005:2
check for the connection og the main wire is cut.. or check the supply..
Dec 07, 2008 | KEF Audio KHT 2005.2 System
KEF KHT 2005.2 SUBWOOFER
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Dec 06, 2008 | KEF Audio KHT 2005.2 System
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
