Question about Sony Ericsson Cyber-shot C902 Cellular Phone
The zero button on the number pad of my sony erriccson c902 is broken. can i allocate zero to a different key?
Unlock code c902
The C902 is a camera phone by Sony Ericsson.
If you purchased your C902 with a cellular plan, it would be locked to your company's network and can only be used with that network.
If you want to switch networks and continue to use your C902, you have to get it unlocked from the current network.
The simplest way to unlock your C902 is through remote IMEI unlocking.
1.Obtain the unlocking code for Sony Ericsson C902 from your network's support desk.
You can call them up and talk to a customer support representative.
Request the unlock code and give them the phone's IMEI number.
As an alternative, you can purchase the unlock code from the websites such as Unlocking,
FonesZone or UnlockItNow.
You will need to provide the IMEI number on the websites.
2.
Close all applications to reach the standby screen of the phone.
3.
Press the left direction key on the navigation pad.
4.
Press the * (asterisks) key twice.
5.
Press the left directional key once again. You will see a menu titled "Personalize."
6.
Select "Network" in the menu. Select "MNC2" in the second menu that appears.
7.
Enter the unlock code you obtained in Step 1 and select "OK." This will unlock the phone.
http://www.mobileunlockguide.com/sony-ericsson-c902
Aug 14, 2013 | Sony Ericsson Cyber-shot C902 Cellular...
Want to unlock and my sim are broken
Don't worry about broken Sim card...While Unlocking You no need Sim card,so after Unlock it You can buy new sim card,So you need to specify the NETWORK and Country it locked now.Get the Unlock code from here
Superunlockcodes.com and Unlock instructions from here
Mobileunlockguide.com and Unlock it step by step,
Unlocking instructions:
Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson C902 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson C902 without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Sep 05, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
Why is almost sonyericsson phones the key pads get scrached easily?like c230i the lower buttons are okey but the upper ones look old.
I am afraid I do not have an answer to this , my sonyericsson was not like that.
Have you noticed weather you push the buttons with your thumbs, a pencil, a pen or even a screwdriver.
Jun 16, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
Locked sony erricson c902
google aerix, not only will it reset the security code to 0000 it will also unlock the phone to any network
Apr 17, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
I have problems typing text messages, the 7 button doesnt wrk...
it happing because c 902 has sticky button the key pad stick with double tape that`s why they stuck some times. try to change the key pad
Dec 15, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
KEY PAD IS LOCKED AND CANNOT UNLOCK IT MY PHONE IS A SONY ERICSSON C902
it sounds as if the keypad is faulty. you need to take it to a repair centre to get it repaired. it should be done under warranty unless there is liquid under the pads.
hope this helps.
g
Oct 07, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
902 wnt turn on bt lights activate
make key pad lights light up (turn on) and leave it like that mine dus it then turns on after 30 secs ,,,,my speaker wen i play music distorts wen turned over half way could you solve this. thanks
hope it helps
Aug 26, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Bluetoothe connection to sony erriccson c902
check your manuel for the unit their will be a code that you have to put in to finish the connection you said you tried 1234 and 0000 but that might not be the right code you can also go into the settings of the device and check all that to see if their is a option in the settings
Aug 07, 2009 | LG LAC-M6500R CD Player
My number 8 button on my keypad has stopped working
dust may be accumulated in key pad if u can try opening the panel and cleaning it or the connector of key pad would have failed try changing it
Jun 18, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
60 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
