Question about Yahoo Messenger
Cant login with my yahoo messenger.it says problem with internet connection but i already checked it and the connection is ok.help me how can i connect to my yahoo messenger.
  • 3 Answers
Posted on Nov 16, 2009
Cant lo.gin say its frozen yahoo messager fix this pleasd
Posted on Apr 23, 2012
Problems with log in to Yahoo Messenger
Hello. You can probably fix this condition by following these steps:
  1. Click on the gear icon in the upper-right of the IE window
  2. Click on Internet Options
  3. Click on the Advanced tab
  4. In the Settings window, scroll all the way down to "Use TLS 1.0" and make sure that is checked.
  5. Click Apply, then OK.
That should fix it for you. This is due to a recent change in how Yahoo handles login requests.
I hope this is helpful.
Jan 25, 2015 | Yahoo Messenger
Can not sign into yahoo messenger ..check your internet connections
First check you correctly type your username and password.
Check if you have internet connection.
if still cant connect try to uninstall and reinstall your yahoo messenger.
If you already did the steps above and you still cant sign in to yahoo, the last thing you will so is call your ISP provider if they have any technical issue that mat affect your connection. Maybe they have selective browsing issue or problem connecting to yahoo.
Sep 14, 2011 | Yahoo Messenger
I cant connect to the yahoo messenger. my ie browser cant connect to the login.yahoo.com. however i can connect with opera browser. what can be the solution to my problem?
Hey!
Yahoo Messenger relies on Internet Explorer for its connectivity settings. It could be possible that some IE settings where changed.
Try checking on the proxy settings.
Here's how to go there:
Open Internet Explorer
Click on Tools
Click on the Connections Tab
Click on LAN Settings
You will see 4 checkboxes, all boxes should not be checked
After correcting settings, just click on OK
Hope this helps! :D
Sep 09, 2010 | Yahoo Mail
Unable to login to yahoo messenger
Reinstall Yahoo Messanger.
Jul 16, 2010 | Yahoo Messenger
I cant open my ym account....
I suggest you to check whether your email address and password is correct or not, by logging in at the www.yahoomail.com website, If you are able to login then your account exists and the email address and password is correct.
If it shows wrong password, try forgot password.
If you are able to login to your account in website, only you cannot login in yahoo messenger, There might be some problem in yahoo messenger, I suggest you to download the recent version of yahoo messenger and try logging in, if problem persists check your internet connectivity, Sometimes we couldn't login if there is a problem in internet connection.
There may also be problem with windows firewall settings.
And also check whether the yahoo messenger is added as exception in the windows firewall or not, If not add the yahoo messenger to exception list.
May 24, 2010 | Yahoo Messenger
Hello my yahoo messenger cant be opened now it tells me yahoo encounted a connection problems but all my other yahoo can open and pls i need to something with it now
Hello Dear , Do Following
  • Try to check Login ID (Correctly type Usr Nam & PW)
  • Check CAPS lock on when typing
  • Check your internet connection
  • IF everything OK
  1. Uninstall your Current Version
  2. Restart pc
  3. Install Latest Version
  4. Login
latest Version Available from Here (You will get simple Set-up File,Run it)
You are Done
Is this TeXT HelPEd you.....
Do RaTE Me.....
thanks for using FixYa
Apr 02, 2010 | Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
Yahoo Problem
try reinstalling the yahoo messenger again,
i too had the same problem ,
and i checked by signing in yahoomail.com to check whether it was a password problem or not, but it was not,
ultimately it was some kind of problem in messenger,
got it fixed bye reinstaling it.
maybe work for you too
Dec 21, 2008 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Dec 16, 2008 | Yahoo Messenger
Yahoo Messenger Logo
399 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
