Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Check the fan no. 1
It says across the screen check the fan no. 1
    President:
  • 4,402 Answers
Fan #1 is out
Posted on Jan 16, 2008
  • Dan Frady Apr 29, 2012
    I had this problem yesterday with my HLT6187s (out of warranty of course). I knew the local TV repair guys would charge hundreds of dollars to fix this, so I decided to tackle it myself. For me it was a very easy fix and it only took 10 minutes once I figured out where "fan no. 1" was.
    1. I unplugged the TV, disconnected all my peripherals and I unscrewed and took off the back cover of the TV
    2. Looking directly at the back of the TV there are two fans, a small one to the left, and a large one to the right.
    3. I figured out that neither of these were fan no. 1 because they were spinning when I turned the TV on.
    4. Just to test, I disconnected the small fan, and tried again and this time it said check "fan no. 1 & no. 2"
    5. I reconnected fan no. 2 and looked for fan no. 1
    6. After about 10 minutes I found it, (it was on the far right side of the TV behind a circuit board.
    7. I unscrewed the circuit board and it slid right out giving me access to fan no. 1
    8. I undid the four screws holding fan no.1 in place (I really only had to undo the bottom two, as the top two aren't attached to anything connected to the TV)
    9. I followed the wire connecting fan no. 1 to its power supply and unhooked it and completely removed the fan.
    10. I throughly cleaned out the fan with a dry wash cloth as it was covered in dust, and plugged it back into its original slot and used my remote to the turn the TV on from behind it.
    11. fan no. 1 was spinning again, so I put it back in its original place, slid the circuit board back in. I turned the TV on again and saw there was no more "check fan no. 1" message so I just screwed everything back in and replaced the back cover.
    12. TV fixed, no need to pay hundreds of dollars to a tech. I didn't even have to replace the fan, but I may end up getting another one just in case it does it again.
    Cary, You are a F'n duesch bag.. Really, Fan #1 is out? You have no solution because you ARE the problem. Her ya go folks... A real answer to your question.
2000 Buick Century 3.1 cooling fans not working.
Check the wiring harness to the fan they sometimes put a fuseable link in the wire and it might of blown.
Mar 19, 2018 | Buick Cars & Trucks
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Minolta dialta 183 help me... theres a code in the screen CO5 .. and automatically turn off.
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Oct 05, 2011 | Minolta DiALTA Di183 Copier
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
Sony KDS-55A2000. bought 1/07. replaced bulb 2/08. gave tv to parents 11/10. worked fine until last week. 1 on screen message, temperature warning (they checked all vents-everything clear and 1' away from...
you will need to check the fans are all switching on when you turn the tv on, it might be one of the fan sensors that has gone bad, the tv wont turn on if it detects that the fans or a single fan is not working. I have not worked on this particular set , but that would be the first place i would look, if you find a fan is not firing up and if you have a multimeter, then check to see if you have a 12v voltage going to the fan, an easy way of rectifying it is to run a wire from one of the other working fans to the positive of the fan that isnt working. This would at least eliminate the fan as the culprit, if the tv starts up normally then the problem lies in why the fan is not receiving power. I ran a tv using this method for over 8 months before it died, from other problems i might add , not the fact i bypassed the fan power circuit.
If you found this info useful please take a moment to vote for me
Mar 30, 2011 | Sony KDS55A2000 55" HDTV
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
Engine cooling fan is not cutting in
timmi400: Check the following:
1) Connection to fan for broken or corroded connector.
2) Check owners manual for fuse controlling the fan.
3) Disconnect fan and put an OHM meter across the fan leads. I should be almost complete short. If no reading at all then the fan is toasted.
Brian
Aug 01, 2008 | Mazda MX-3 Cars & Trucks
Spots on the screen
Really dusty house, hey,,,, Take apart screen assy and vacume then dust with microfiber clothe. Use can air and brush to clean fans. Dust is enemy #1 to all DLP tv's
Jan 03, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
545 people viewed this question
Jerry Greenberg
Jerry Greenberg
