Question about Microsoft Xbox Console
My xbox told me to down load and since then it will not work and i keep getting a red light
  • 33 Answers
Either you need to be refurbished or you can go to llama.com and delete that update theyll walk you through it at the bottom of the page
Posted on Nov 22, 2009
How to Stop the Red Ring of Death on Xbox?
Hi Carolyn,
- notice poor game performance (if your games start taking a long time to load, or they become stutter or crash, it may be indicative of a looming hardware failure)
-notice poor system performance (if your system locks up, even when not playing games, this is a sign of hardware failing).
- understand the different light codes
Green-green lights indicate that console is powered and operating properly
1 red light-Hardware fault. Usually followed by E74 code on TV
2 red lights-overheating error. If the console becomes too hot, the system will shut down and display this light code
3 red lights-general hardware failure also known as the red ring of *****
4 red lights-AV cable isnt currently plugged in
If you do get red ring of *****:
- purchase a fix kit
-have console professionally fixed
-have console sent in to microsoft
-Prevent red ring of *****-understand what causes hardware failure
-keep your system in a well ventilated area
- avoid long gaming sessions
-keep system horizontal
-avoiding stacking items on xbox
-clean gaming area
-dust xbox
Oct 20, 2016 | Video Game Consoles & Games
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
Hi my xbox keeps knocking off and 3 flashing red lights appear why is this i just received a new xbox accessory pack and still wont work.
3 red lights mean your xbox had overheated. you should leave your xbox off for a while and let it cool down. if that didnt work then that means stuff has melted to your motherboard inside im guessing. good luck
Feb 19, 2010 | Microsoft Xbox Console
Red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
My xbox has 2 red lights it keeps overheating but the heat sinks dnt get hot
Wrap it in a couple of towels and let it run, 10-15 minutes, it will overheat and shut down and the three red lights will be flashing, then turn it off, let it cool, 15-30 minutes, turn it back on and bam, it should work, granted its not a permanent thing but it will work from a week-month, from then on the red ring of death will appear when it shuts down instead of the 2 lights, and you can either fix it yourself, do the towel trick again, or just send it to Microsoft if the warranty is still intact. trust me it works.
Jun 11, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
My x box is not loading any games and only showing the green x on screen and only showing 2 red lines on front panel
The two red lights means overheating. Either let your console cool down; or vacuum the vents on the back of the xbox to get the dust out. For further assistance, call 18004MYXBOX.
Tip: Keep you xbox on a cool ventilated area.
Apr 02, 2008 | Microsoft Xbox 360 Console
Won't load game keeps blinkng red light
If the XBOX 360 is blinking the color RED in three of the four quarter of the ring around the power button, you will have to contact Microsoft for a replacement. This is what is known as "Red Ring of Death." You can find plenty of information on it if you Google it.
Click HERE for a video of the Red Ring of Death.
Click HERE for Microsoft's support system for the XBOX 360 and get in touch with Microsoft to get your replacement started.
It's the ONLY way.
Good luck.
Cyryl
Dec 10, 2007 | Microsoft Xbox 360 Console
Xbox 360
Is this happening?
If you get those 3 red lights call Microsoft as they have extended the warranty on all xbox's to cover this issue for 3 years. Their phone number is 1-800-4MY-XBOX
Nov 13, 2007 | Video Game Consoles & Games
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
