Question about Motorola Mobility S9 Headphones
Tell me how to change passkey in motorola s9 blowtooth headgset..
Motorola S9 batery wont last
do not know where to buy
mine last 1 month
5-6 recharge
heelllp!
Posted on Nov 16, 2009
How do i replace motorola s9 battery?
The battery cannot be changed.
Mark
Motorola Support
Jul 14, 2014 | Motorola Mobility MOTOROKR S9 Wireless...
Need to know process for making my s9(red/black) discoverable
Press and hold the power key (under the red cover) longer than the time required to turn it on, until its indicator light is alternately flashing in red and blue. It is in pairing mode (discoverable) now. Then, make your phone (or computer)'s bluetooth application search for new devices. After a little while, the S9 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the S9 should enter the stand-by mode. There could be such an indicaton in your phone (or computer) too.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Mar 28, 2011 | Motorola Mobility MOTOROKR S9 Wireless...
I have metro pcs phone service and a motorola s9 bluetooth headset i cant get the passcode.
Press and hold the power key (under the red cover) longer than the time required to turn it on, until its indicator light is alternately flashing in red and blue. It is in pairing mode (discoverable) now. Then, make your phone's bluetooth application search for new devices. After a little while, the S9 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the S9 should enter the stand-by mode. There could be such an indicaton in your phone too.
Regards, Carlos
Mar 07, 2011 | Motorola Mobility S9 Headphones
How do I put the motorola s9 hd wireless headset in pairing mode for a iPhone 3G ?
Starting with your headset turned off, press and hold the power button for some 6 seconds, until the indicator light flashes alternately in blue and red. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a while the S9 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros). The indicator light will flash some times and enter stand-by mode.
Regards, Carlos
Sep 01, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
My s9 headphone not on of work tell me wath i do
make sure you charge the S9 using a motorola mini usb AC charger or a mini USB cord plugged into a live port.
press and hold the circle vertical bar until the light is steady blue and pair it with your bluetooth device. you only have two buttons at the rear of the device under the motorola logo.
Aug 28, 2010 | Motorola Mobility S9 Headphones
Stopped recieving music through the headphones but continue to get calls. Any ideas
You could try re-pair it again. On your device, remove the partnership with the headst. Then, press and hold the power button for more than 3 seconds, until the led is solidly lit. It is in pairing mode now. Make your device search for new devices again. After the S9 appears on the device's screen, select it and make it connect. If a pairing code (or PIN, or passkey) is requested. enter '0000' (four zeros).
Regards, Carlos
Jun 07, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola s9 battery dead how to replace it. for replacement is there it is just use and throw one only? please let me know
After googling the problem, I saw a couple of PDF documents that said that Motorola would replace or change the battery, but the links to the documents were outdated. At this site, they said the battery is non-replaceable: http://direct.motorola.com/ens/s9/Headset_Home.asp.
I found this site for support, and it looks like it might be worth a try:
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=26428dda028e0210VgnVCM1000008406b00aRCRD
It looks to me like the battery can be replaced, at the service level, but that normally it is a throwaway item at the consumer level. See if they can help you, but, of course, get the price first, and that will tell you whether to have it fixed or replaced. Good luck, and hope this helps.
May 25, 2010 | Motorola Mobility S9 Headphones
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
PAIR KEY FOR MOTOROLA s9
Bluetooth headsets have their passkey hardcoded by their manufacturers. So, I'm afraid it is not suitable to be changed. However, once any two bluetooth devices are paired, their link is encrypted. You see, you put your headset in pairing mode only when you want to pair it to a specific device of yours (i.e. phone, PC, etc.). Once they are paired to each other, third devices won't be able to get into that connection.
Just my 2 cents...
Regards, Carlos
Feb 21, 2009 | Motorola Mobility S9 Headphones
Motorola s9
THe Motorola S9 is not an mp3 player. You can't download anything to it. Sorru
Jul 12, 2008 | Motorola Mobility S9 Headphones
Motorola Mobility S9 Headphones Logo
293 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
ka4iup
ka4iup
john h
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
