Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Loud static type snap from tv
For a while there is a loud snap and the screen goes out ( less than .5 sec )
It sounds like static . It is now quite often. I removed the back cover and there was bright spark from one of the 3 circuit boards. It appears on the board but not always in exact same area of board.
  • 579 Answers
TV's use high voltage to generate the stream of electrons traveling across the picture tube hitting the screen and lighting it up (thus the name Cathode Ray Tube). It takes about 25,000 volts to do this. In normal air, it takes about 1000 volts to jump an inch of air, so the high voltage transformer needs to have good insulation. It generates the voltage through a technique of charging the transformer's magnetic field with a low voltage of about 140 volts then letting it go where upon it flys back out the high voltage side at much high levels (Thus the common name flyback). A most common failure in a CRT type TV is for the insulation to crack in this transformer which is a unique component for each model of TV and leak out the current overstressing the circuit driving it. You can liken it to a little bolt of lightning getting loose in the circuit and has the same sound on a smaller scale.
It would be well to replace your flyback transformer before it gets worse and blows up something else as well. Best done by a professional used to handling high voltage. The picture tube can retain voltage even when the TV is unplugged for some time, and replacing the anode lead (the big red one) can be dangerous.
Hope Ya Fix It!
Posted on Jan 09, 2008
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
I have no sound on my TV . It may work for about 5 minutes but then I get a loud static noise and the sound goes out completely
If your television have no sound or works for a period of time and goes out after a loud static noise, then there is a problem with the unit. Try to connect a DVD player to it to see if it will do the same, if it does the same, then it means the problem is from the television.
The problem is that the sound IC is bad and need to be replaced. The sound IC is on the main board, once the television is disassembled, you will have to trace the wires at the back of the speaker to the board it is mainly connected to, that is your sound IC, it is bad and need to be replaced
Hope this helped.
Goodluck
Elect_Comp
Jun 27, 2011 | Televison & Video
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
Loud static Noise
that sertainly doesn't sound normal to me
Jul 29, 2009 | Televison & Video
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
