Question about Samsung SyncMaster 2233BW 22" LCD Monitor
I have a Samsung 2233 LCD Monitor and using it as an HDTV connected to DirectTV with HDMI port. The picture keeps ghosting on the faces and I have tried playing with settings without any help.
  • 863 Answers
See if there is an updated driver you need.  Otherwise, your screen is fu.k.d up, which these particular models are know for cause they are always selling refurbished ones.
Posted on Nov 15, 2009
I have just bought a 2233sw and have been researching what sources it can receive directly with out a pc. As this is not a LCD tv it is much more fussy about what it will display correctly - from reading this post I see that it needs to be a (1080)p signal not a (1080) i - the p is for progressive - basically any conversion is usually handled by the operating system of the pc - so without that buffer for your media player to be giving exactly the right kind of signal. Whether it is a HMDI tv or dvd or whatever. I doubt that there is any need for any drivers or repair to your monitor - you just need to address the issue of the source matching the display. Keep googling - and don't give up on the monitor.
Posted on Dec 03, 2009
How can i connect DirectTV to the hp 1740 monitor ?
Your HP 1740 Monitor uses:
  • One 15-pin mini D-sub analog VGA
  • One DVI-D (VGA analog or digital)
as for your DirectTV box you have at least an RCA and a HDMI to connect to Display devices that "DOES'NT MATCH" with your preferred monitor.
Your only chance to make it happen is to get a HDMI to DVI adapter (like this one: http://images.thomann.de/pics/prod/249861.jpg ) to output your digital box to your monitor.
Aug 22, 2014 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
I have a 37'' Samsung LCD flaf screen tv and the picture all of a sudden is not clear. It is hooked up to directv box and the two other tv's that I have are clear. I also have a Wii hooked up to the tv and...
Try different ports. Use and HDMI cable and see if it is doing on it. If you are using a HDMI cable now hook the connection up with the component cables and see if it is doing the same thing. If it is clear on one of the other ports you have a port on your mainboard that is bad.
Feb 10, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
DLP TV keeps flickering
Please recheck component connections in both units and make sure to hook up them according to corresponding colors like blue to blue, red to red and orange to orange.
Dec 13, 2008 | Samsung HLN5065W 50" Rear Projection...
Westinghouse 47 in LCD HDTV
cfusion.com has the mainboard for that. it sounds like you just need a new one, it looks like its about $169
Apr 07, 2008 | Westinghouse LTV-46w1 HD 46 in. LCD...
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
541 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
