Question about HP Compaq Presario SR2170NX (RK549AA#ABA) PC Desktop
I took pc into office depot to get it checked as monitor has no signal display, even after buying new monitor. They got the same thing, said need a video card, after purchasing it I put it in and still has same message..what now?
  • brandyvee Nov 15, 2009
    no it came with a new cable
  • agent_009_87 May 11, 2010
    Did you use the same cable for the monitor or did you use a new one?
    Problem Solver:
  • 19 Answers
There is a possibilty that the pci slot isnt working on your motherboard. try a different pci slot with the new video card.If all are occupied then swap one to test. if your using agp, well you only have one agp slot so go to pci. just use generic first dont get anything expensive when your testing.
Posted on Nov 15, 2009
Hi my pc boots and fans are spinning like normal
You need to check the monitor also. The LED monitors do not last as long as the old CRT's. Also try a different cable. The LED monitors I have had usually stop working without warning. They will turn on but cannot display a picture.
Oct 19, 2014 | Computers & Internet
Dual monitor vs Large monitor?
Or go through this page and see.
Whether it's helpful to you or not?All the Best!
Thanks for using FixYa.
Apr 26, 2012 | Dell Optiplex GX520 (GX520 2.8) PC Desktop
I bought an hp 2211x monitor and a lenovo pc from office depot and everything seems to work except the audio. I checked everything and it says that the speakers or headphones are not plugged in. I have no...
It is possible they aren't compatible but it is more likely the outfit you bought has something missing.
Sometimes the speakers are integrated into the monitor but the connection to these is by a separate audio cable from the PC.
If the speakers aren't integrated into the monitor you will need a suitable active speaker system that should arrive with a power supply and all other leads ready wired and just need plugging into the PC.
Consulting the instruction manual is a good way of learning where to plug things in. Most conventional PCs have three jack sockets close together and some are usefully colour coded - One is audio out and another is audio in but I can't remember the third.
It is possible your new PC is entirely USB and has many USB sockets but few of the more familiar sockets. If that is the case you will need a pair of USB speakers.,,
I suggest you contact the supplier for advice...
Aug 11, 2017 | Office Depot Computers & Internet
Installed Office Depot ink cartridges, BCI 6 C and Y in my MP780. Worked ok at first, but then started getting "wrong cartridge" msg, Per canon rep, turned off mach, disconnected power, took out...
This is an example of why 2nd class refills are junk. I would try to gently clean the printer out. While a lot of people disagree with this advice, a mixture of 90% alcohol in a tiny pipit works well. Then use some lint free q-tips. Most cartridges have electronic chips on them that report the status of the cartridge. Refilled ink cartridges may have bad or defect chips.
Jan 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
No signal
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 16, 2010 | AOpen F2705 17" LCD Monitor
Trying to get an eithernet driver for this machine
You may be better off adding a new Ethernet card instead since this model has had onboard ethernet problems in the past. I have even had to remove ethernet chips from these PC's just to get the computer running again. Ethernet cards are dirt cheap and quite easy to buy at office max, office depot, bestbuy, walmart and other places.
Aug 30, 2010 | E-Machines etower 400i PC Desktop
Where can I buy a lcd cable for a md2614u?
If you mean for connecting an external LCD display, the cables are available in store or online:
Fry's
Best Buy
maybe Office Depot/Max
Your laptop has a VGA monitor port, not a DV/I port, in case you are asked...
Oct 08, 2009 | Gateway Computers & Internet
HP a400n monitors
Sure but you shouldn't need to tell the computer what type of monitor it is, windows should simply send the signal to the monitor and poof up comes your display, more advanced versions may auto-detect or youc an select it in the control panel under display. Try craigslist to pick up a cheap monitor in your area. I got a 15'' flat for 20 bucks.
Aug 12, 2008 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
HP Compaq Presario SR2170NX (RK549AA#ABA) PC Desktop Logo
53 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
