Question about Toshiba 55H70 55" Rear Projection Television
Top 6" only thing viewable.
Top 6 inches of picture working fine, everything else black snow flowing from right to left. Sound is also distorted. will not power off either.
  • Toshiba Master
  • 8,617 Answers
If you go to the following link we have the service manual for you set for 10.99 and we provide unlimited chat support so you can diagnose and repair your set. Just click on toshiba and you will find your model number. Then click on the contact us link and provide your email address we will then email your manual along with instructions on how to enter into the chat sessions. Hope this helps you out.
http://servicemanuals.vstore.ca/
Posted on Jan 13, 2008
6ya staff
SOURCE:
How to widen my curtis 42 inch flat sreen top and bottom
Some TV's have a zoom function others do not. The program you're watching controls whether the top and bottom of the screen have black bars and is not the fault of the TV. Widening the picture cuts off a lot of the viewable picture and distorts the image. Circles tend to be oval. If your TV has a zoom function, use it.
Jan 21, 2017 | Top Computers & Internet
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Distortion when music play
click on start and right click on
computer.click on properties.on the left
hand top corner click on device
manager.here double click on sound video and game controller now right click on idt high definition audio codec and uninstall.after that close all the windows and retstart the system.everything should work fine.
Jan 08, 2010 | Computers & Internet
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Picture beginning to fail
PITCURE IS GREEN AND PURPLE
Jul 13, 2008 | Televison & Video
Panasonic 32" picture reduction
IT IS LESS WIDTH PROBLEM It has to be done by tech person as inside tv high voltage is thare so unskilled person should not open tv. problem is simple. 1 less output from regulated power supply . 2 if width control is there it can be done by that.
Sep 17, 2007 | Panasonic CT-32SL14 32" TV
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Black comes across right side of screen
Sounds like you've got whats called a cold solder connection somewhere in the horizontal width control circuit or a connection in the sweep section. Should'nt be two expensive but unless you have had some soldering and troubleshooting experience I would leave this on to the pros. Good Luck
Jun 02, 2006 | JVC AV-36D502 36" TV
Toshiba 55H70 55" Rear Projection Television Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
