Question about Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf220
Won't empty after wash, how do I locate the filter or the drain to empty.
Lou
  • Hotpoint Master
  • 3,463 Answers
If ther is no filter at the front of washer, then remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose, also remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Posted on Nov 15, 2009
Washing machine won't empty making buzzing noise and coming up with f.05
looks like your drain filter is clogged. There could be cents, matches or something like that. All this stuff do not let to spin drain motor clearly.
Apr 13, 2013 | Washing Machines
Does not complete the cycle or empty the water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Hotpoint Aquarius WF220 Front Load Washer
How to get to filter on aquarius extra washing machine
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble in reverse order.
Dec 16, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint washing machine WF430- Where would my filter be located as it needs to be emptied?
Its located at the rear of the machine, adjacent the drain pump, held with jubilee clips. You only have undo the main one. Filter is like a small, holed basket with a plastic ball. Empty anything in there and make sure you place the plastic ball back, tighten jubilee clip.
Jan 04, 2010 | Hotpoint Washing Machines
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint WF320 wont spin or empty
sounds like something is jamming the pump, strip pump down and clean
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing machine won't spin
check the pressure switch the unit wont spin unless it knows all the water is out of the unit
May 28, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
263 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
