Question about Dell Inspiron 9300 Notebook
My battery will not recharge and the volume does not work
  • 3,940 Answers
Battery:
Portable batteries are consumable and have a expected lifespan of roughly 300 to 500 recharge/discharge cycles before replacement is required. If you are using the original battery, then most likely you need a new one. If battery is a new replacement and you have the same issue, flash the BIOS to most current, see if any change. If not change, and a new battery doesn't charge, then replace the motherboard.
Volume:
You were not clear if this is a NO SOUND or just VOLUME IS LOW issue. For NO SOUND
  1. Open Volume Control, Ensure that sound is not muted.
  2. Control Panel, Sound and Volume controls. Ensure that the sound card is selected as the primary playback device.
  3. BIOS, ensure the Audio is Enabled.
  4. Download and reinstall the audio driver.
If you are just talking about the volume control displaying on screen, reinstall the quickset utility
Posted on Nov 15, 2009
I have a KXTGE440 cordess phone it has a dial tone and I can dial out ok but incoming calls don't ring?
Do you have rechargeable NI MH rechargeable batteries?
Is Call Blocking on?
Is answering on with two rings?
Have you tired to adjust the volume of both the handset and base station?
Lift handset
Press + or - repeatedly to select the desired volume. - Repeatedly To turn the ringer off.
Base unit Press - or + repeatedly to select the desired volume. To turn the ringer off, press and hold - until the unit beeps
Sep 17, 2017 | Lands Phones
Volume on my iHome is too quiet, fix please?
You an inline battery powered signal booster, they are cheap.
Sep 23, 2016 | iHome iBT60 Bluetooth Rechargeable Mini...
Unlock code for lg l34c. what is it
Don't know of a code. If there was one, and everyone knew it, it wouldn't make sense to lock your phone. Here is one way to do a factory reset but you'll lose your data on your system memory.
Try turning it off, then restart holding power and volume button down. If that doesn't work, try power and volume button down. You should get a menue.
Jun 26, 2015 | Empire LG L34C Cell Phone Battery Li-Ion...
How to reapire the volume
Bluetooth might have been defected in the electronic board.
you can isolate problem by try it on different phone.
if the problem follows, drained all the battery and then recharged
and try it again. If this still does not work you might want to
think about invested money on newer one. Hope this help.
terry
Jun 23, 2014 | Jabra SP700 Bluetooth Car Kit
Ge cb radio
Possibly a bad volume/on/off volume potentiometer. Try using canned air around the volume/on/off knob to remove any debris down along the shaft. If this does not help, your unit may need repair. Do not use any chemicals, cleaners or solvents on the shaft, only use air.
Clean your internal battery contacts on the batteries and the radio with a pencil eraser to assure good connection. If you are using rechargeable batteries, try charging the batteries again.
Best regards.
Sep 28, 2013 | GE Hand Held Cb 40 Channel Model 3-5980a...
Sandisk clip won't recharge
Make sure the lock switch is not engaged first.
Try another USB port on your computer.
If it still won't take, try this:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Wet psp volume and home does not work, can not recharge battery
Your PSP is bricked, and unfortunately this cannot be fixed because its a hardware brick. The PSP needs to be replaced.
Sorry
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
Short Battery Charge
Hello Dave2794875,
According to manufacturer specifications the NiMH rechargeable batteries should provide about 12 hours of operating time assuming a 90/5/5 operating cycle (90% standby, 5% receive, and 5% transmit). Theoretically, decreasing the volume can help somewhat but should have a minimal effect.
If you are only seeing two hours of standby time then you are definitely not getting the specified amount of time. This could be indicative of a problem with the charger or the battery pack or both.
Using disposable alkaline AAA batteries, you should see an increase in operating time because alkaline batteries have more capacity and last longer then rechargeable batteries. However, if yu do a lot of operating the cost of disposable AAAs can add up fast. For most users the rechargeable batteries are much less expensive in the long run. If you only use the radio occasionally then alkaline batteries are the way to go.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jul 26, 2008 | Uniden GMR-1558 / 2CK 2-Way Radio
Dell Inspiron 9300 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
